Then, I can simply do the following: (There is no need of # directive.)
pinMode(2, INPUT_PULLUP);
But, why have I been prompted to do like this: #define INT0 2? It is due to the presence of the symbolic name INT0 as an interrupt source in the data sheets (Fig-1).
I will try your codes tomorrow Inshallah! Now, in my country it is 2:46 by the morning; myself being an aged man should go to bed. Thank you for the help and participation.
One can certainly trigger on the leading edge of the change if one ignores any bouncing that occurs afterwards. So there is no need to wait for the contacts to settle. IMHO the best approach to handling pushbuttons is to have a timer interrupt and poll the pushbuttons within that roughly every 10ms. For most AVR based Arduinos, the existing library has taken the timer 0 overflow interrupt for timing (like implementing micros() and millis()) uses, but a compare interrupt can be used to make an additional "systick" interrupt (note that it can be interfered with by PWM). So for instance:
ISR(TIMER0_COMPA_vect) { // Interrupt occurs every 1.024ms
static byte count; // Only execute every 10.24ms
if (count > 0) {
count--;
count = 10;
/* DO THE POLLING HERE */
Then the polling for an active low pushbutton on, say, digital pin 2 would be:
static bool last_button2 = HIGH;
bool button2 = digitalRead(2);
if (button2 == LOW && last_button2 == HIGH) {
/* TAKE ACTION -- BUTTON JUST PRESSED */
last_button2 = button2;
I am proud and greatly honored to receive very high quality reactions/suggestions on my post from almost all the veteran members of the Forum. I will go through each of the posts with humble care and academic/practical enthusiams. I will let you know my findings and will ask for clarification if needed. There are so many good ideas in your posts being presented in the form of codes/texts, which I would never know should I not make the post because of sighness or lack of courage!
The issue that I have wished to understand is this:
The ISR (3 times blinking of LED1 at 500 ms interval) is being executed in the loop() function. As the blinking of LED1 is in progress using a for() loop, the MCU is again interrupted due to bouncing of the interrupting device (the K1). As a result, the MCU jumps to the ISR, sets the flag (which is already set = true) and comes back to within for() loop of the loop() function. Becasue, the index value of the for() has not changed, the interrupt process should be ending after 3 blinks; instead, there are more than 3 blinks -- 4 or 5 or even more. I have wanted to understanad the true cause of this phenomenon and then implement appropriate remedy to this undesired behavior of the interrupt process without changing the hardware setup.
Because flag is set to false in the loop function after the flashing is completed, something is setting it to true after those 3 seconds in order for it to continue flashing. I don't know what type of switch you are using, but it is extremely unlikely that the contact would still be bouncing after 3 seconds, which would point to some flaw in the switch hardware.
But there is problem with your code. The attachInterrupt function should specify FALLING and not LOW. LOW will cause repeating interrupts and should only be used if the condition causing the low level is removed in the interrupt routine.
That point is @GolamMostafa ignoring for a long time now.
Level interrupts are only viable if the source can be controlled by the ISR,
but @GolamMostafa does not want to install a high voltage user remover.
These important clues have come only now and I remember my experinece with 8259 chip (Interrupt Priority Controller) where we used to apply the above-mentioned tricks to clear the LOW-level sustaining trigger signal to avoid multiple interrupts to 8085/8086.
Honestly speaking, I had not been ignoring your idea; rather, I was trying to understand, actually, what was going on.
This is (Fig-1) how I am going to implement your above idea in order to demonstarte that the allowable LOW level trigger mode (Fig-2) could still be used to generate non-multiple interrupts for the MCU.
I remember and admit; but, I had difficulties to relate those with the issue of my Post-1 of the current thread. It could be, myself being a non-native, that I did not perceive the intelligence being conveyed.
