Here's the code for a 2 button foot-controller that will send midi messages to a looping pedal. Using simpler code, I've checked the midi transmit function and the button connections, but when I put them into this debounced SWITCH statement, nothing is sent out.
The general premise seems to have worked on previous pedals, I just can't see the error and I'm at the outer edge of my programming skills ;(
Any general coding tips, especially regarding redundant code is also appreciated!
// midi controller for line 6 HX effects to control looper
// july 19
#include <MIDI.h>
#include <midi_Defs.h>
#include <midi_Message.h>
#include <midi_Namespace.h>
#include <midi_Settings.h>
MIDI_CREATE_DEFAULT_INSTANCE();
// Constants
#define SWITCH1 2 //rec/play
#define SWITCH2 3 // stop
#define SWITCHES 2 // how many switches?
int switches[SWITCHES] = { SWITCH1, SWITCH2};
int switchState[SWITCHES] = { LOW, LOW }; // Initial state of switch
int currentSwitch = 0;
int recording = 0; // state or recording
unsigned long SwitchMillis = 0; // when button was released
unsigned long DebounceMillis = 20; //
unsigned long CurrentMillis = 0;
MIDI.begin(1);
for ( currentSwitch = 0; currentSwitch < SWITCHES; currentSwitch++ )
pinMode( switches[currentSwitch], INPUT ); // Set pin for switch
digitalWrite( switches[currentSwitch], HIGH ); // Turn on internal pullup
CurrentMillis = millis(); // get the time at the start of this loop()
if (CurrentMillis - SwitchMillis >= DebounceMillis) //is it time to check the switches?
SwitchMillis = millis(); //re-initilize Timer
if ( (digitalRead(switches[currentSwitch]) != switchState[currentSwitch] ) && (switchState[currentSwitch] == HIGH) )
switch ( currentSwitch )
case 0: // rec or play
if (recording == 0)
MIDI.sendControlChange(60, 0, 1); // rec
recording = 1;
MIDI.sendControlChange(60, 127, 1); // play
recording = 0;
case 1: // stop
MIDI.sendControlChange(61, 0, 1); // stop
} // end switch
} // end digiread
} // end go through switches
switchState[currentSwitch] = digitalRead( switches[currentSwitch] );
} // go time to check switches
} // end loop
is after your for loop. currentSwitch is probably 2 at this point which also means that you're writing off the end of your array. You can prove it to yourself by printing currentSwitch.
Try moving that statement up into the for loop i.e. above the brace that's just before it.
} // end switch
} // end digiread
The way you have this written you have to read the switch twice and it may not have the same value each time. Also, you can't print the state as it is before the IF test
Robin - after some head-scratching, I think I have implemented your idea and it seems to work!
The code is now
// july 19
#include <MIDI.h>
// Constants
int prevSwitchState[SWITCHES] = { HIGH, HIGH };
MIDI.begin(1);
readSwitches();
if (switchState[currentSwitch] == HIGH and prevSwitchState[currentSwitch] == LOW)
if (recording == 0)
MIDI.sendControlChange(60, 127, 1); //rec
recording = 1;
MIDI.sendControlChange(610, 127, 1); // play
recording = 0;
case 1: // stop
} // end cases
} // end is state changed
} // end of check time loop
} // end loop
void readSwitches() {
prevSwitchState[currentSwitch] = switchState[currentSwitch]; // save the old version
switchState[currentSwitch] = digitalRead(switches[currentSwitch]);
You might consider refactoring loop: it's long and has a lot of control constructs in it, which led to the problem I mentioned above being hard to see.
While I was trying to figure out what was wrong, I took your switch statement and put it in a function of its own which shrank loop down enough that I could see it all at once.
