Plss help. The Circuit has 2 buttons(from pin 3 and 4 to GND) and 1 LED(from pin 2 to GND). button1 toggles on/off while button2 blinks the LED if button1 is HIGH. I can’table to blink the LED using button2 while button1 is HIGH.
#include "ClickButton.h"
// the LED
const int ledPin = 2;
int ledState = 0;
// the Button
const int buttonPin1 = 3;
const int buttonPin2 = 4;
ClickButton button1(buttonPin1, LOW, CLICKBTN_PULLUP);
ClickButton button2(buttonPin2, LOW, CLICKBTN_PULLUP);
// Arbitrary LED function
int LEDfunction = 0;
int LEDfunction2 = 0;
//int LEDfunction2 =
pinMode(ledPin,OUTPUT);
// Setup button timers (all in milliseconds / ms)
// (These are default if not set, but changeable for convenience)
button1.debounceTime = 20; // Debounce timer in ms
button1.multiclickTime = 250; // Time limit for multi clicks
button1.longClickTime = 1000; // time until "held-down clicks" register
button2.debounceTime = 20; // Debounce timer in ms
button2.multiclickTime = 250; // Time limit for multi clicks
button2.longClickTime = 1000; // time until "held-down clicks" register
// Update button state
button1.Update();
button2.Update();
// Save click codes in LEDfunction, as click codes are reset at next Update()
if(button1.clicks == 1 && button2.clicks == 0)
ledState = !ledState;
if(button1.clicks == 1 && button2.clicks == 1)
ledState = (millis()/500)%2;
digitalWrite(ledPin,ledState);
The ledState is a logic variable you have assigned it a value based on the millis time. Why have you done that? You can only write 0 or 1 not a value to a digital pin.
