Debouncing working unpredictbly.
Hello Everyone!
I'm new to Arduino programming (actually I'm good at software programming but not an expert.) the code of Arduino isn't working as I expect.
I'm working on the debouncing code. the idea is I have 6 LEDs (from pin 2 to 8) attached on the breadboard and incorporated a counter that counts how many time a push button is pressed and those numbers of LEDs are turned on.
ie: If I press pushbutton 4 times then 4 LEDs should on and other remain off.
But as I upload program, All LEDs remain turned on. 2 numbers are added instead of one to counter everytime I press the button.
Here is the code. Please Let me know what I'm doing wrong.
//////////////////////Declarations//////////////////
boolean lastButton = LOW;
boolean currentButton = LOW;
int counter = 2;
int pushbutton = 2;
///////////////////////////setup///////////////////
  pinMode (pushbutton, INPUT);
  for (int i=3;i<=8;i++){
    pinMode (i, OUTPUT);
  Serial.begin (9600);
///////////////Debouncing/////////////////
boolean debounce (boolean last) {
  boolean  current = digitalRead (pushbutton);
  if (last != current) {
    delay (130);
  return current;
//////////////////////LOOP///////////////////////
  currentButton = debounce (lastButton);
  if (currentButton != lastButton) {
    counter ++;
    Serial.print (counter);
    Serial.print (" ");
  for (int i=3; i<=8;i++){
    digitalWrite (i,HIGH);
  if (counter == 9){
    counter = 3;
  delay (100);
  lastButton = currentButton;
If you are not reading switches correctly, it is almost always a wiring issue. INPUT expects you to be using a switch AND a pullup or pulldown resistor, which requires more complicated wiring than INPUT_PULLUP.
How IS your switch wired?
Do you have a pulldown resistor (10k) from pin 2 to GND?
The only place where you write to your LEDs is here:
You always set all of them on, every time. Did you want to have them come on based on count?
    digitalWrite (i, count >= i);
Note: HIGH==1==true and LOW==0==false so you can use any true/false statement for the pin value.
This makes no sense to me
    delay (130);
  return current;
If you want to avoid bounce then you should wait a short interval (such as 50 millisecs) before you read the I/O pin to allow time for the mechanical switch state to settle.
If you only want to respond to the switch if it has been released after the last input then you need to compare the current value with the last value and only return a switch-pressed indication if the current is different from the previous and if the current value shows that the switch has been pressed. For example
if (newValue != prevValue and newValue == LOW) { // assumes LOW when pressed
   switchPressed = true;
else {
   switchPressed = false;
prevValue = newValue;
return switchPressed;
...R
for debouncing, I like:
byte readButton() {
  static byte reading = LOW;
  static uint32_t bounceMs;
  if(millis() - bounceMs > 50) {
    byte prevReading = reading;
    reading = digitalRead(thePin);
    if(reading != prevReading) bounceMs = millis();
  return reading;
Also, what everyone else said about pullup and pulldown resistors.
