Hi;
I realize this problem is out of scope with respect to the Arduino IDE, but I did notice other posting regarding the use of Atmel Studio on this forum, so I thought I'd try my luck.
Using a due, atmel studio 6.2 and a jtagice3, it appears that anytime I hit a breakpoint & then continue, timer ISRs stop firing. The loop function continues running. This happens with both JTAG and SWD debug interfaces.
I can provide examples if necessary, although that involves a lot of work to bring in the arduino libraries to atmel studio. An easier way to see the problem is to use a simple atmel studio boilerplate example for the sam3x8e/Due.
In Atmel Studio 6.2:
- Choose File -> New -> Example project
- Device Family = Sam32bit, Category = Applications
- Select "Getting-started application on SAM - Arduino dueX"
- Click OK
If you start debugging, AS will trap at entry to main() & you can continue with no problems. But, if you place a break anywhere in the while(1) loop, I find that the delay function (called mdelay in the ASF example) never returns, because the SysTick_Handler ISR has stopped being called.
A couple other things I noticed:
- Mechanisms involving TC0 behave the same way
- A hard coded bp using asm ("BKPT 0xAB") will also stop the ISRs
