Debug code setup problem
I have created a small debug code at the start of all my sketches I can enable or diable with the first line
DEBUG = (0 OFF 1 ON)
#define DEBUG 1
#if DEBUG == 1
#define debug(x) Serial.print(x)
#define debugln(x) Serial.println(x)
#else
#define debug(x)
#define debugln(x)
#endif
it removes and disables any Serial.print or Serial.println in the sketch to save on memory, works quite well,
HOWEVER...
if i use something like;
debug(mbyte, DEC);
OR
debugln(mbyte,DEC);
i get the error code:
HEX DEC BIN Tables from 0-254/HEX DEC BIN Tables from 0-254.ino:26:21: error: macro "debugln" passed 2 arguments, but takes just 1
exit status 1
Compilation error: macro "debugln" passed 2 arguments, but takes just 1
I know its probably a simple fix to be able to use the code and i've hsmmered my head for hours and googled a lot with no help.
Am I just stupid??!! :melting_face:
Thanks in advance!!
you define debug() with one parameter
but call it with two
debug(mbyte, DEC);
hence the error message
Can you try something like this instead?
#if DEBUG == 1
  #define debug   Serial.print
  #define debugln Serial.println
#else
  #define debug   (void)
  #define debugln (void)
#endif
I guess that will generate a warnings when DEBUG==0 so maybe something like this instead:
#if DEBUG == 1
  #define debug(...)   Serial.print(__VA_ARGS__)
  #define debugln(...) Serial.println(__VA_ARGS__)
#else
  #define debug(...)
#endif
THANK YOU!!!!! That did it! I assumed that just defining them would work but im guessing it just didnt know what to do with the extra command?
