debug my codes plz cc3000+l298n
hi
this code of wifi cc3000 and l298n
who can find where are the mistakes in my codes the connection in serial monitor shows its fine and connect but when i gave it a command forward or backward its not moving
// Libraries
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include <aREST.h>
#include <avr/wdt.h>
// CC3000 pins
#define ADAFRUIT_CC3000_IRQ   3
#define ADAFRUIT_CC3000_VBAT  8
#define ADAFRUIT_CC3000_CS    10
const int IN1=4;
const int IN2=5;
const int IN3=6;
const int IN4=7;
// CC3000 instance
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT);
// Create aREST instance
aREST rest = aREST();
// The port to listen for incoming TCP connections
#define LISTEN_PORT           80
// Server instance
Adafruit_CC3000_Server restServer(LISTEN_PORT);
#define WLAN_SSID       "i put my wifi name"
#define WLAN_PASS       "my pass"
#define WLAN_SECURITY   WLAN_SEC_WPA2
void setup(void) {
   // Start Serial
  // Give name to robot
  rest.set_id("1");
  rest.set_name("robot");
  // Expose variables to REST API
 // rest.variable("distance",&distance);
 rest.function("forward",FORWARD);
  rest.function("backward",BACKWARD);
  rest.function("left",LEFT);
  rest.function("right",RIGHT);
  rest.function("stop",Stop);
  // Set up CC3000 and get connected to the wireless network.
  if (!cc3000.begin())
    while(1);
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    while(1);
  while (!cc3000.checkDHCP())
    delay(100);
  // Start server
  restServer.begin();
  Serial.println(F("Listening for connections..."));
  displayConnectionDetails();
  // Init sensor
  //dht.begin();
  wdt_enable(WDTO_4S);
  // Handle REST calls
  Adafruit_CC3000_ClientRef client = restServer.available();
  rest.handle(client);
  wdt_reset();
  // Check connection
  if(!cc3000.checkConnected()){while(1){}}
  wdt_reset();
int FORWARD(String command){
  analogWrite(IN1,0);
  analogWrite(IN2,200);
  analogWrite(IN3,200);
  analogWrite(IN4,0);
  return 1;
int BACKWARD(String command){
  analogWrite(IN1,200);
  analogWrite(IN2,0);
  analogWrite(IN3,0);
  analogWrite(IN4,200);
    return 1;
int RIGHT(String command){
  analogWrite(IN2,0);
  analogWrite(IN3,150);
  analogWrite(IN4,0);
    return 1;
int LEFT(String command ){
  analogWrite(IN1,0);
  analogWrite(IN2,150);
  analogWrite(IN3,0);
    return 1;
int Stop(String command){
  analogWrite(IN1,0);
  analogWrite(IN2,0);
  analogWrite(IN3,0);
  analogWrite(IN4,0);
    return 1;
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
    return true;
if no one know can you suggest a websites can help me plz
Hi -
As an old (& rusty) programmer, IMHO the best way to debug a program, that looks and compiles fine no errors, is to strictly follow the instructions in your code manually :
Very patiently step by step, one instruction at a time.
Make up a table of all (and I mean ALL !) variables and pins used.
At each step in your code, fill your table with applicable values and pin states, using pen & paper.
I guarantee, that after a few instructions, you will find either an error or mistake in the logic method, i.e. the idea, behind your code.
OR a problem (limitation) in your hardware.
Also remember :
Fill your code with comments on what the code is intended to do.
This is especially important and useful, if you are a beginner (or a rusty old gent like me ...) :wink:
everything is right in my codes there is not any errors even the connection is ok but only when i gave command of forward right...etc its not accepted and nothing moves
I'm not a fan of aRest, but maybe try some debug prints in the library?
ok do u know another way to control the robot via wifi :frowning:
ok this another codes i wrote it the connection is ok but when i write the command in the serial monitor
of F - S - R - L - B its only accept the first command ex: i put F in serial monitor as i first direction but when i command B as a second it dosnt response
plz i need just correction i dont want to pay for some one to correct my codes and i knew its right
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include <stdlib.h>
String result;
const unsigned long
  dhcpTimeout     = 60L * 1000L, // Max time to wait for address from DHCP
  connectTimeout  = 15L * 1000L, // Max time to wait for server connection
  responseTimeout = 15L * 1000L; // Max time to wait for data from server
uint32_t t;
#define WLAN_SSID       "AFAQShamel"        // cannot be longer than 32 characters!
#define WLAN_PASS       "0508344390"
#define WLAN_SECURITY   WLAN_SEC_WPA2 // This can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIV2);
#define LISTEN_PORT 8888
Adafruit_CC3000_Server robotServer(LISTEN_PORT);
const int IN1=4;
const int IN2=5;
const int IN3=6;
const int IN4=7;
pinMode( IN1 ,OUTPUT);// Right Motor 1st wire
pinMode( IN2 ,OUTPUT);// Right Motor 2nd wire
pinMode( IN3 ,OUTPUT);// left Motor 1st wire
pinMode( IN4 ,OUTPUT);// left Motor 2nd wire
  result = "";
 Serial.println(F("\nInitializing..."));
    Serial.println(F("Couldn't begin()! Check your wiring?"));
    while(1);
    Serial.println(F("Failed!"));
    while(1);
  Serial.println(F("Connected!"));
  Serial.println(F("Request DHCP"));
    delay(100); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (! displayConnectionDetails()) {
  // Start listening for connections
  robotServer.begin();
    Adafruit_CC3000_ClientRef client = robotServer.available();
  if (client) {
     boolean currentLineIsBlank = true;
     // Check if there is data available to read.
     while (client.available()) {
       char c = client.read();
       result = result + c;
       Serial.write(c);
       // Delete HTTP headers
      if(result.endsWith("Content-Type: text/html"))
        result="";
       if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");
          client.println();
       if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
     // give the web browser time to receive the data
    delay(5);
    // close the connection:
    client.close();
    Serial.println("client disconnected");
    // Format result and extract the variables
     result = "";
  char input;
  // check if data has been sent from the computer:
    // switch based on the character
    if (Serial.available()) {
    // read the most recent character
   input = Serial.read();
    switch(input){
      case 'F':
        // forward
  analogWrite(IN1,0);
  analogWrite(IN2,255);
  analogWrite(IN3,255);
  analogWrite(IN4,0);
      case 'B':  // backwards
           // v=Serial.read();
  analogWrite(IN2,0);
  analogWrite(IN3,0);
      case 'S':  // stop
        analogWrite(IN1,0);
  analogWrite(IN2,0);
  analogWrite(IN3,0);
  analogWrite(IN4,0);
      case 'L':  // left
  analogWrite(IN1,0);
  analogWrite(IN3,0);
      case 'R':  // right
  analogWrite(IN1,150);
  analogWrite(IN2,LOW);
  analogWrite(IN4,LOW);
      default:    // if character not recognized then stop
        analogWrite(IN1, 0);
        analogWrite(IN3, 0);
    bool displayConnectionDetails(void){
    return false;
    return true;
