Debug output window buffer
Hi, everytime I use the debug mode when uploading I am annoyed about that the window buffer of the output window is too small to hold the debug output, even then when uploading the only the small blink sketch. Also I find that the -v-v-v-v mode gives too much information. Can I enlarge the window buffer? Is it possible to change to -v-v verbose mode? Any other solution possible? Regards Reinhard
in the preferences.txt file add/change this line
console.length=500
Note that the IDE must be closed when editing this file..
BTW not tried higher values..
I tried console.length=50000.
Works well also with long outputs
Meanwhile I found a second way to bypass the problem
In my Ubuntu installation the IDE creates a directory at \tmp named “console.tmp”
In this directory you will find two files containing the information from the output/debug window.
The directory is deleted when you quit the IDE.
Now only one question is open:
erni-berni:
Not without recompiling the IDE unless you get version 1.5
