Debugging ADM1602k LCD Display
I've hooked up the lcd to my arduino assuming I did it correctly. I followed this tutorial(link in bottom) and I followed all the steps. The only part I think that might giving my LCD trouble is the contrast setting. It says that pin 3 on the LCD controls the contrast, so I used a 10k potentiometer and that didnt work and I tried to use various resistors set to pin 3 to see if that would change the contrast but nothing. First of all, this was my assumption after uploading the code and it not working that the problem the contrast.
datasheet:
tutorial: http://www.dreamdealer.nl/tutorials/connecting_a_1602a_lcd_display_and_a_light_sensor_to_arduino_uno.html
thanks guys, this is is my first personally arduino project.
edit: i fixed it the problem was the pot i just used a different one and made sure the pins had a sure connection
