Debugging is not really working
I'm using a Nano-ESP32 and I want to enable Debugging.
The documentation https://docs.arduino.cc/tutorials/nano-esp32/debugging is not really working.
Do I have to use the normal com-port or the DFU-port? In the documentation there is a screenshot which says, that Is have to select DFU-Mode, but no DFU-Mode is available. Sometimes it's working with the normal COM-Port with the generic-name ESP32S3 Dev Module. After stepping through single lines, in the sourcecode there is no mark as it used to be in previous IDE2 versions like
I need some help please.
Thanks!
Erik
I have the same problem! No DFU-Mode!
Hello @EriksArduino , please let us know more about what are you trying to do, what steps you followed, what was your expected result. Thanks! :slight_smile:
Maybe you can also find advice in the Debugging Guide or in the Reset the Arduino bootloader on the Nano ESP32 documents.
I have merged your cross-posts @EriksArduino.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
The "double click" seems to be a bit tricky because the second click has to be after the LED turns from reddish to fading green. If done right, the board sets the LED to green.
Hey @EriksArduino , just wanted to add that the Debugging guide has just been updated - it should answer many of your questions on serial ports and device name.
Hope this helps, let us know!
