Hello, I have a problem with my loop where it is something that after a while hick up it...
What I am doing. I am blinking LEDs from digitalPin 10 and I have a indication on pin 7 that lights up another LED that the program is on. While I have pushed the button I start this program, to power this I use a powerbank and to keep it alive I use a function to send a signal to the powerbank every 4 sec that, hey we are still running do not sleep.
Everything works fine but after a maybe 30 sec the Pin 8 that puts out signal every 4 sec is constantly HIGH.
My guess is that it is something that hick up in this section
if (flashFlag == true)
//flashing timer
//is it time to toggle the LED ?
if (micros() - flashMircos >= interval)
//restart timer
flashMircos = flashMircos + interval;
//toggle LED
digitalWrite(LEDpin, !digitalRead(LEDpin));
digitalWrite(onIndicationLED, HIGH);
keepAlive();
Here are the full code
#define PUSHED LOW
#define LEDon HIGH
#define LEDoff LOW
#define firstFrequency 100//100 Hz
#define secondFrequency 200//200 Hz
#define thirdFrequency 250//250 HZ
//Switch connection
//+5V---[internal pullup resistor]---[input]---[switch]---GND(0V)
const byte startSwitch = 2;
const byte LEDpin = 10; //[output pin]---[LED >|]---[220R]---GND/0V
const byte keepAlivePin = 8;
const byte onIndicationLED = 7;
byte currentState;
byte lastStartState;
byte lastStopState;
byte frequencyCounter;
bool flashFlag = false;
//timing stuff
unsigned long onIndicationMillis;
unsigned long keepAliveMillis;
unsigned long switchMillis;
unsigned long xMillis;
unsigned long flashMircos;
//const unsigned long xMinutes = 10 * 60 * 1000ul; //10 minutes
const unsigned long xMinutes = 20 * 1000ul; //for testing use only 4 seconds
const unsigned long timeOne = 1000000ul / (firstFrequency * 2);
const unsigned long timeTwo = 1000000ul / (secondFrequency * 2);
const unsigned long timeThree = 1000000ul / (thirdFrequency * 2);
unsigned long interval;
static int last = 0;
static bool keepAliveSignal = false;
pinMode(onIndicationLED, OUTPUT);
pinMode(keepAlivePin, OUTPUT);
pinMode(LEDpin, OUTPUT);
pinMode(startSwitch, INPUT_PULLUP); //pushed/closed = LOW
interval = timeOne;
} //END of setup()
//check the switches every 50ms
//time to check our switches ?
if (millis() - switchMillis >= 50)
//restart timer
switchMillis = millis();
checkSwitches();
//is flashing enabled ?
//flashing timer
//restart timer
//toggle LED
keepAlive();
//X minute timer
//has X minutes expired ?
if (millis() - xMillis >= xMinutes)
//restart the timer
xMillis = millis();
//next frequency
frequencyCounter++;
if (frequencyCounter == 1)
interval = timeTwo;
else if (frequencyCounter == 2)
interval = timeThree;
else if (frequencyCounter > 2)
//disable flashing
flashFlag = false;
//turn LED OFF
digitalWrite(LEDpin, LEDoff);
digitalWrite(onIndicationLED, LEDoff);
digitalWrite(keepAlivePin, LOW);
} //END of if (flashFlag == true)
} //END of loop()
void keepAlive()
if (millis() - last > 4000) // cycle length 4 s
digitalWrite(keepAlivePin, HIGH);
last = millis(); // record the time when pulse actually goes high
keepAliveSignal = true;
if (keepAliveSignal && millis() - last > 450) // wait until AT LEAST 450 ms has passed
void checkSwitches()
//Start switch
currentState = digitalRead(startSwitch);
//has the switch changed state ?
if (lastStartState != currentState)
//update to the new state
lastStartState = currentState;
//when we 'are not' flashing, was the switch just pushed/closed ?
if (flashFlag == false && currentState == PUSHED)
//start the x timer
xMillis = millis();
//initalize frequency counter
frequencyCounter = 0;
//select the flash frequency
interval = timeOne;
//start the flashing timer
flashMircos = micros();
//enable flashing
flashFlag = true;
else if (flashFlag == true && currentState == PUSHED)
//disable flashing
flashFlag = false;
//turn LED OFF
