debugging objects and some others about arrays
Hi all!
I'm working with the RFM22 library from Mike McCauley, the library works great but when I use it to build a datagram network it fails after some time, and I wrote some VB application to analize what is wrong with it.
Now when I dump the datagram object I fount a hex value like this: FFFFFF84
I mean i get the data byte per byte, like this:
0F 0A 01 FFFFFF84 00 02 0D ....
What can be this FFFFFF84 value? a mem pointer could be?
And other issue is about an array, is this valid ?
uint_8t my array [255];
mifunction (array,&lenarray); // this is a function that fills the arrays with 200 values and lenarray let me know with how many was filled
//and then i add more values to the arrar
myarray[lenarray] = 201;
myarray[lenarray+1] = 202;
myarray[lenarray+2] = 203;
lenarray = lenarray+3;
Is this code correct? it's working but is this codding the right way to add member to the array?
Best Regards!
Frank
No, simply any byte value with sign-extension (0x84)
Can i leave this sign-extension value or is better try to found who produce it to set like an unsigned value?
It's my first time wih the sing-extension situation!
Best Regards
Frank
You could simply cast to a unsigned type.
