here I want to report about my experience with debugging on an
ATtiny84 with 16 MHz external clock on a selfmade board.
For debugging on the ATtiny84 I used a 16x2 LCD with I2C interface
because ATtiny84 has no HW UART. But I found that print statements
to this LCD require very long time.
To find a suitable method for debugging I compared HW Serial with
19200 baud, SoftwareSerial with 19200 baud, and LCD with I2C interface
on an Uno (also 16 MHz clock). I tested print statements with 1 and
3 digits, floating point, and a combination of number and string
with following results:
print(5) print(543) print(3.1415) print(...)
HW 21392 125464 177488 489500
SW 58832 172772 244196 549248
LCD 98292 461780 630288 1515380
print(...) means "print(iv); print(" U/min");" (iv with 4 digits)
All times are microseconds for 100 print statements in a loop.
I was surprised about the long duration of HW Serial and even LCD.
I had expected much shorter durations.
HW Serial printed to the Serial Monitor and LCD to a connected LCD
display. For SoftwareSerial no Monitor was connected.
Because of the results I decided to use SoftwareSerial on ATtiny84.
To program the ATtiny84 I use a programmer USBasp via ISP connector
on the board. To avoid plugging and unplugging between programming
and testing I selected MISO and MOSI pins as Rx and Tx (pins 5, 6) of
SoftwareSerial. These pins are connected via a plug adapter to a
FTDI board for serial to USB conversion. The overall wiring is shown
in the attached schematic.
With this setup I can modify sketches, upload them to the controller,
and see the print outputs on the Serial Monitor of my Arduino IDE
without changing any connections.
I tested it with an ATtiny84 but it should work with any ATtiny.
Remark: be aware that SoftwareSerial uses timer1 (16 bit) and may conflict with sketches using timer 1 also.
Meantime I have learned that just typing "Serial.begin(baudrate);" can be used as if a HW UART were onboard. Really the USI HW in the chip is used for that purpose, and no conflicts with using timer 1 will occur.
Posting https://forum.arduino.cc/t/minimizing-flash-ram-use-for-just-hwserial-rx-on-attiny/854526/8 allows to minimize flash and RAM.
