I agree that busy waiting is incorrect, and I will resolve this. I wanted to double check the logic here though - the reason I am testing TXBUFE is due to this language in the data sheet:
The following list gives an overview of how status register flags behave depending on the counters’ values:
ENDRX flag is set when the PERIPH_RCR register reaches zero.
RXBUFF flag is set when both PERIPH_RCR and PERIPH_RNCR reach zero.
ENDTX flag is set when the PERIPH_TCR register reaches zero.
TXBUFE flag is set when both PERIPH_TCR and PERIPH_TNCR reach zero
These status flags are described in the Peripheral Status Register.
Each peripheral connected to the PDC sends out receive ready and transmit ready flags and the PDC sends back flags to the peripheral. All these flags are only visible in the Peripheral Status Register.
I took this to mean that status flags can only be accessed through the peripheral's status register - not the DMA controller register. The only flags in the DMA controller's status register (PTSR) are whether the transfer and receive channels are enabled - I don't think those flags change when transfers end:
The PDC has dedicated status registers which indicate if the transfer is enabled or disabled for each channel. The status for each channel is located in the associated peripheral status register. Transfers can be enabled and/or disabled by setting TXTEN/TXTDIS and RXTEN/RXTDIS in the peripheral’s Transfer Control Register.
At the end of a transfer, the PDC channel sends status flags to its associated peripheral. These flags are visible in the peripheral status register (ENDRX, ENDTX, RXBUFF, and TXBUFE). Refer to Section 26.4.3 and to the associated peripheral user interface.
