Debugging the code: TensorFlow lite and Nano 33 BLE sense
Hi everyone!
I turn to you as I am out of ideas about how to debug this!
I am running a TensorFlow lite model on the Nano 33 BLE sense. The model is used to recognise an object placed in front of the Nano and then print the index 1, 2 or 3 depending on the results from the Tensor Flow Lite Object Classifier code. The sketch runs as intended if I comment out all the BLE related code, I get either 1, 2 or 3 printed out on the serial monitor.
I have tested the BLE code by commenting out all the TensorFlow lite code and using the proximity sensor on the Nano, this also works as intended and I am able to see this data in the LighBlue app on my phone.
The problem I have is when I run the sketch with the TensorFlow Lite and the BLE together. I don't get any error messages, the code compiles and I see 0's printed on the Serial but as soon as I try to scan an item with Nano it makes the program crash - the Serial freezes and LED starts flashing on the Nano.
int CLASSES [4] = {3,2,1}; This used to be const char * CLASSES [] = {"3","2","1"} ; I had to change it to int to be able to use it with the buttonCharacteristic.writeValue(buttonValue);
I would much appreciate any suggestions or thoughts on what could be going wrong here.
Also maybe someone knows a way to debug Arduino code like in Thonny where you can see step-by-step what is happening in the program?
  Object classifier by color
  Uses RGB color sensor input to Neural Network to classify objects
  Outputs object class to serial using unicode emojis
  Note: The direct use of C/C++ pointers, namespaces, and dynamic memory is generally
        discouraged in Arduino examples, and in the future the TensorFlowLite library
        might change to make the sketch simpler.
  Hardware: Arduino Nano 33 BLE Sense board.
  Created by Don Coleman, Sandeep Mistry
  Adapted by Dominic Pajak
  This example code is in the public domain.
// Arduino_TensorFlowLite - Version: 0.alpha.precompiled
#include <TensorFlowLite.h>
#include <tensorflow/lite/experimental/micro/kernels/all_ops_resolver.h>
#include <tensorflow/lite/experimental/micro/micro_error_reporter.h>
#include <tensorflow/lite/experimental/micro/micro_interpreter.h>
#include <tensorflow/lite/schema/schema_generated.h>
#include <tensorflow/lite/version.h>
#include <Arduino_APDS9960.h>
#include "model.h"
// global variables used for TensorFlow Lite (Micro)
tflite::MicroErrorReporter tflErrorReporter;
// pull in all the TFLM ops, you can remove this line and
// only pull in the TFLM ops you need, if would like to reduce
// the compiled size of the sketch.
tflite::ops::micro::AllOpsResolver tflOpsResolver;
const tflite::Model* tflModel = nullptr;
tflite::MicroInterpreter* tflInterpreter = nullptr;
TfLiteTensor* tflInputTensor = nullptr;
TfLiteTensor* tflOutputTensor = nullptr;
// Create a static memory buffer for TFLM, the size may need to
// be adjusted based on the model you are using
constexpr int tensorArenaSize = 8 * 1024;
byte tensorArena[tensorArenaSize];
// array to map gesture index to a name
int CLASSES[4] = {3, 2, 1};
// u8"\U0001F34E", blue 3 //
// u8"\U0001F34C", green 2//
// u8"\U0001F34A"  red 1//
#define NUM_CLASSES (sizeof(CLASSES) / sizeof(CLASSES[0]))
#include <ArduinoBLE.h>
BLEService ledService("19B10010-E8F2-537E-4F6C-D104768A1214"); // create service
// create button characteristic and allow remote device to get notifications
BLEIntCharacteristic buttonCharacteristic("19B10012-E8F2-537E-4F6C-D104768A1214", BLERead | BLENotify);
  while (!Serial) {};
  //begin initialization
  if (!BLE.begin()) {
    Serial.println("starting BLE failed!");
    while (1);
  if (!APDS.begin()) {
    Serial.println("Error initializing APDS9960 sensor.");
  // get the TFL representation of the model byte array
  tflModel = tflite::GetModel(model);
  if (tflModel->version() != TFLITE_SCHEMA_VERSION) {
    Serial.println("Model schema mismatch!");
    while (1);
  // Create an interpreter to run the model
  tflInterpreter = new tflite::MicroInterpreter(tflModel, tflOpsResolver, tensorArena, tensorArenaSize, &tflErrorReporter);
  // Allocate memory for the model's input and output tensors
  tflInterpreter->AllocateTensors();
  // Get pointers for the model's input and output tensors
  tflInputTensor = tflInterpreter->input(0);
  tflOutputTensor = tflInterpreter->output(0);
  // set the local name peripheral advertises
  BLE.setLocalName("nano33");
  // set the UUID for the service this peripheral advertises:
  BLE.setAdvertisedService(ledService);
  // add the characteristics to the service
  ledService.addCharacteristic(buttonCharacteristic);
  // add the service
  BLE.addService(ledService);
  buttonCharacteristic.writeValue(0);
  // start advertising
  BLE.advertise();
  Serial.println("Bluetooth device active, waiting for connections...");
  int r, g, b, p, c;
  int buttonValue;
  float sum;
  //poll for BLE events
  BLE.poll();
  // check if both color and proximity data sample is available
  while (!APDS.colorAvailable() || !APDS.proximityAvailable()) {}
  // read the color and proximity sensor
  APDS.readColor(r, g, b, c);
  p = APDS.readProximity();
  sum = r + g + b;
  // check if there's an object close and well illuminated enough
  if (p == 0 && c > 10 && sum > 0) {
    // normalize
    float redRatio = r / sum;
    float greenRatio = g / sum;
    float blueRatio = b / sum;
    // input sensor data to tensorflow
    tflInputTensor->data.f[0] = redRatio;
    tflInputTensor->data.f[1] = greenRatio;
    tflInputTensor->data.f[2] = blueRatio;
    // run inferencing
    TfLiteStatus invokeStatus = tflInterpreter->Invoke();
    if (invokeStatus != kTfLiteOk) {
      Serial.println("Invoke failed!");
      while (1);
      return;
    // output results
    int maxPercent = -1;
    int maxIndex = -1;
    for (int i = 0; i < NUM_CLASSES; i++) {
      int percent = (int(tflOutputTensor->data.f[i] * 100));
      if ( percent > maxPercent) {  //maxPercent is currently highest percentage from the i that the for loop has gone through
        maxPercent = percent;
        maxIndex = i;
      (CLASSES[i]);
      ("%\n");
    Serial.print(CLASSES[maxIndex]);
    buttonValue = CLASSES[maxIndex];
    // wait for the object to be moved away
    while (!APDS.proximityAvailable() || (APDS.readProximity() == 0)) {}
  Serial.println(buttonValue);
What made you think that your question has anything to do with the Website and Forum section which is clearly stated to be for "Improvements for the web system, applications to moderator, spam, etc."? I have suggested to the Moderator to move it to the Programming section.
This sort of carelessness makes unnecessary work for the Moderators.
Please read How to get the best out of the Forum
...R
