debugging
i need help in getting this program to work. at present it is having errors. i am trying to interface accelerometer adxl345 (inactivity interrupt) with arduino. the program is given below.
#include <SPI.h>
int cs = 10;
int intr = 2;
int buzzer = 4;
int relay = 5;
int su = 1;
int intr1
pinmode (buzzer,OUTPUT);
pinmode (relay,OUTPUT);
char POWER_CLT = 02D
char DATA_FORMAT = 0
31
char DATAX0 = 032
char DATAX1 = 0
33
char DATAY0 = 034
char DATAY1 = 0
35
char DATAZ0 = 036
char DATAZ1 = 0
37
char THRESH_ACT = 024
char THRESH_INACT = 0
38
char TIME_INACT = 026
char INT_ENABLE = 0
2E
char INT_MAP = 02F
char ACT_INACT_CTL = 0
27
char INT_SOURCE = 0*30
char values[10];
char output[20];
int x, y, z;
char inactivityevent = 0;
SPI.begin();
SPI.setDataMode(SPI_MODE3);
pinMode(cs,OUTPUT);
digitalWrite(cs, HIGH);
attachInterrupt(digitalpintointerrupt(intr),interruptHandler,RISING);
writeRegister(DATA_FORMAT,001);
writeRegister(POWER_CTL,0
08);
writeRegister(INT_MAP,0F7 && 0EF);
writeRegister(THRESH_INACT,1);
writeRegister(TIME_INACT,0);
writeRegister(ACT_INACT_CTL,00F);
writeRegister(INT_ENABLE,0
08);
readRegister(INT_SOURCE,1,VALUES);
void interrupHandler()
read register (INT_SOURCE,1,values);
intr1=digitalread(intr);
if ( intr1==high)
read register(DATAX0,6,values);
x = ((int)values[1]<<8|(int)values[0]);
y = ((int)values[3]<<8|(int)values[2]);
z = ((int)values[5]<<8|(int)values[4]);
if ( x<=15 && x>=-15 && y<=10 && y>=-10 && z>=75 && z<=90)
digitalwrite(buzzer,HIGH);
digitalwrite(relay,LOW);
for (int i=0;i<=90;i++)
delay (2000);
if (intr == LOW)
{ break(); }
if (i==90)
while (su=1)
if (intr==LOW)
digitalwrite(buzzer,LOW);
digitalwrite(relay,HIGH);
break();
And they are . . ?
Please please use code tags when posting code
Like this if ( intr1==high)
Oops
Which character do variable declarations end with ?
Just to help AWOL a bit :smiley:
Arduino: 1.6.6 (Windows 8), Board: "Arduino/Genuino Uno"
test:21: error: exponent has no digits
        char INT_ENABLE = 0 * 2E
test:39: error: invalid digit "8" in octal constant
   writeRegister(POWER_CTL, 0 * 08);
test:44: error: invalid digit "8" in octal constant
   writeRegister(INT_ENABLE, 0 * 08);
test:8: error: expected initializer before 'pinmode'
 pinmode (buzzer, OUTPUT);
test:9: error: expected constructor, destructor, or type conversion before '(' token
 pinmode (relay, OUTPUT);
test:10: error: unable to find numeric literal operator 'operator"" D'
 char POWER_CLT = 0 * 2D
C:\Users\sterretje\Documents\Arduino\Projects\Forums\test\test.ino: In function 'void setup()':
test:37: error: 'digitalpintointerrupt' was not declared in this scope
   attachInterrupt(digitalpintointerrupt(intr), interruptHandler, RISING);
test:37: error: 'interruptHandler' was not declared in this scope
test:38: error: 'DATA_FORMAT' was not declared in this scope
   writeRegister(DATA_FORMAT, 0 * 01);
test:38: error: 'writeRegister' was not declared in this scope
test:39: error: 'POWER_CTL' was not declared in this scope
test:40: error: 'INT_MAP' was not declared in this scope
   writeRegister(INT_MAP, 0 * F7 && 0 * EF);
test:40: error: 'F7' was not declared in this scope
test:40: error: 'EF' was not declared in this scope
test:41: error: 'THRESH_INACT' was not declared in this scope
   writeRegister(THRESH_INACT, 1);
test:42: error: 'TIME_INACT' was not declared in this scope
   writeRegister(TIME_INACT, 0);
test:43: error: 'ACT_INACT_CTL' was not declared in this scope
   writeRegister(ACT_INACT_CTL, 0 * 0F);
test:43: error: unable to find numeric literal operator 'operator"" F'
test:44: error: 'INT_ENABLE' was not declared in this scope
test:45: error: 'INT_SOURCE' was not declared in this scope
   readRegister(INT_SOURCE, 1, VALUES);
test:45: error: 'VALUES' was not declared in this scope
test:45: error: 'readRegister' was not declared in this scope
C:\Users\sterretje\Documents\Arduino\Projects\Forums\test\test.ino: In function 'void interrupHandler()':
test:50: error: 'read' was not declared in this scope
   read register (INT_SOURCE, 1, values);
test:50: error: expected ';' before 'register'
C:\Users\sterretje\Documents\Arduino\Projects\Forums\test\test.ino: In function 'void loop()':
test:55: error: 'intr1' was not declared in this scope
   intr1 = digitalread(intr);
test:55: error: 'digitalread' was not declared in this scope
test:56: error: 'high' was not declared in this scope
   if ( intr1 == high)
test:58: error: 'read' was not declared in this scope
     read register(DATAX0, 6, values);
test:58: error: expected ';' before 'register'
test:59: error: 'values' was not declared in this scope
     x = ((int)values[1] << 8 | (int)values[0]);
test:64: error: 'digitalwrite' was not declared in this scope
       digitalwrite(buzzer, HIGH);
test:74: error: expected ';' before '(' token
           break();
test:74: error: expected primary-expression before ')' token
           break();
test:77: error: 'digitalwrite' was not declared in this scope
           digitalwrite(relay, LOW);
test:84: error: 'digitalwrite' was not declared in this scope
         digitalwrite(buzzer, LOW);
test:86: error: expected ';' before '(' token
         break();
test:86: error: expected primary-expression before ')' token
         break();
exit status 1
  enabled in File > Preferences.
Nah, serious.
I would start fixing the missing semicolons. You would see the below if you auto-format the code in the IDE. Incorrect indentations are an indication of a missing semi-colon, curly etc.
                 char DATA_FORMAT = 0 * 31
                                    char DATAX0 = 0 * 32
                                        char DATAX1 = 0 * 33
An other error is referring to octal numbers. If you use a number like 01, the compiler expects an octal number; 08 is not a valid octal number.
Why do you use something like char DATAX0 = 0 * 32; would it not just be easier to write char DATAX0 = 0;?
And 2E is not a hexadecimal number, it is a double that is missing an exponent.
