DebugWIRE Arduino vs ICSP PIC debugging
Hello, I'm getting started at debugging, and I own an Atmega168 (Arduino Diecimilla) and a PIC16F873A. I own an MPLAB-ICD2 for PIC debugging and an AVR Dragon for Atmega.
I'd like to know which debugger is more comfortable, faster or reliable in your opinion.
I've heard that DebugWIRE uses only 2 wires, but when changing from debug to program you've to enable/disable debug fuses and so on. I don't know how works the ICSP debugging on PIC.
For my debugging I need to watch variables, and a play/pause button if possible.
Any advice, explanation is highly appreciated.
Martin.
Most of the members here will only have Atmel AVR experience and a handful will have AVR Dragon experience.
Dragon can emulate the Atmega328P, http://www.atmel.no/webdoc/atmelstudio/supported.devices.AVR.Mega.html
One (at least) of our members has experience: http://forum.arduino.cc/index.php/topic,167110.0.html You may wish to ping them via PM... But Please post your experiences so that a record is available of how this goes!
Ray
My advice is: don't use a hardware debugger.
A lot of microprocessor programming is timing dependent, and as such a debugger will not be particularly useful.
For examining variables, a simple Serial.print will usually do the trick.
In a very similar manner.
REGISTER 14-1: CONFIGURATION WORD (ADDRESS 2007h)(1) : DEBUG: In-Circuit Debugger Mode bit 1 = In-Circuit Debugger disabled, RB6 and RB7 are general purpose I/O pins 0 = In-Circuit Debugger enabled, RB6 and RB7 are dedicated to the debugger
Note that the auto-reset circuitry on a Arduino interferes with debugWire.
