Hello everyone, i need to measure the air resistance and roll resistance of a vehicle. I plan on using a toothed disc with a proximity sensor which will output a square wave signal in to an arduino. Then I will drive until I reach a certain speed, after which I will disconnect the drive from the wheels and let the vehicle roll until it has reached another certain speed (2 or 3 kph lower than the speed at which I started). By measuring the time it takes to decelerate I can calculate the air and rolling resistance.
I want to use an arduino as the brain box. Once the frequency of the sensor signal drops below a given value the arduino should start measuring time. Once the frequency drops below a second given value the arduino should stop measuring. For example between 25Hz and 20Hz. I would like to change the Frequency (that corresponds to a speed) so i can test at different speeds. I would then want to log the time it took to my pc on the serial monitor. I plan on using an Arduino Mega 2560.
My knowledge of coding in C is very limited so I'm a bit stuck on how I would write such a program. Anybody got any ideas on how to program something by using interrupts? The vehicle on which I want to do this is an Urban Concept car for the Shell Eco-marathon efficiency race.
There are lots of examples of frequency counting. The rest of your code can be a simple state machine:
enum states {WAITING_FOR_START, READY_FOR_START, RUNNING} State;
unsigned long ReadyFrequency = 30; // Speed above start frequency where run can start
unsigned long StartFrequency = 25; // Speed at which timing starts
unsigned long StopFrequency = 20; // Speed at which timing stops
unsigned long StartTime, StopTime;
while (!Serial); // Wait for USB connection on Leonardo/Micro
State = WAITING_FOR_START;
switch (State) {
case WAITING_FOR_START:
if (Frequency() > ReadyFrequency) {
Serial.println(F("; Ready to start a run."));
State = READY_FOR_START;
case READY_FOR_START:
if (Frequency() <= StartFrequency) {
StartTime = millis();
Serial.println(F("; RUN STARTED."));
State = RUNNING;
case RUNNING:
if (Frequency() <= StopFrequency) {
StopTime = millis();
Serial.println(F("; RUN FINISHED. Elapsed time in milliseconds:"));
Serial.println(StopTime - StartTime);
// Someone has to write this part
unsigned long Frequency() {
return 0;
@johnwasser that looks a lot like what we need! I see you say there's still a part missing that someone has to write. What function has this missing part?
Ok, let's start with Mr. johnwasser's program. Would this work if i write this extra piece about 'unsigned long Frequency()' or am i missing something? Thanks for thinking with me!
int inpin =13;
while (!Serial);
pinMode(inpin, INPUT);
switch (State) {
State = RUNNING;
case RUNNING:
unsigned long StartTime1=0, StartTime2=0,Time=0, Frequency;
int counter1=1, counter2=0;
while(counter1!=4)
while(~digitalRead(inpin))
if(counter1 == (counter2 +1))
if(StartTime2==0)
StartTime2 =millis();
StartTime1 =millis();}
else if(StartTime2!=0){
StartTime2 = StartTime1;
counter2 = counter1;
if(counter1==counter2)
Time += (StartTime1-StartTime2);
counter1 += 1;
Frequency = 1/(Time/1000);
return Frequency;
unsigned long StartTime1 = 0, StartTime2 = 0, Time = 0, Frequency;
int counter1 = 1, counter2 = 0;
while (counter1 != 4)
while (~digitalRead(inpin)) // WRONG OPERATOR! Use '!' for logical NOT.
// Note: This is NOT going to detect a pulse edge. To do that you have to detect a CHANGE of state
if (counter1 == (counter2 + 1))
if (StartTime2 == 0)
StartTime2 = millis();
StartTime1 = millis();
else if (StartTime2 != 0) { // REDUNDANT! StartTime2 is either == 0 or != 0. No need to check both
if (counter1 == counter2) // REDUNDANT! This condition will always true
Time += (StartTime1 - StartTime2); // Does this mean there are four pulses per revolution?
counter1 += 1;
Frequency = 1 / (Time / 1000); // INTEGER DIVIDE BY ZERO! If less than 60 RPM (1 RPS)
// ZERO RESULT! If more than 120 RPM (2 RPS)
// Try: Frequency = 1000 / Time; Works from 60 RPM to 60000 RPM
return Frequency;
Im trying something different, what do you guys think of it? I'm getting the frequency on the serial monitor but not most of the time or not in combination with the total program ...
int inpin =3;
unsigned long StartTime, StopTime,f;
int setFlank=0, counter=0;
while (!Serial);
attachInterrupt(digitalPinToInterrupt(3), set, RISING);
void loop() {Serial.println(F("test1")); Frequency();
switch (State) {
f=Frequency();
f=Frequency();
State = RUNNING;
case RUNNING:
f=Frequency();
unsigned long TimeNew=0, TimeOld=0,TimeTotal=0, Frequency=0;
int counter=0;
while(counter!=3)//measure time betweenv 3 flanks, 2 periods
if(setFlank)
setFlank = 0;
if(TimeOld==0)//first cycle, old and new should be the same for correct calculation of total time
TimeNew =millis();
TimeOld = TimeNew;}
else{
TimeOld = TimeNew;
TimeNew =millis();}
counter ++;
TimeTotal += (TimeNew-TimeOld);
Frequency = 2000/TimeTotal; //TimeTotal divided by 2 (2 periods) and 1000(milliseconds)
Serial.println(Frequency);
return Frequency;
void set()
setFlank =1;
It would make more sense to capture the value of millis() in the ISR, instead of just setting a flag. Otherwise you have no need for interrupts, you can just poll a pin. The whole point of the interrupt is to avoid the loop() latency.
I work together with the OP on this project. We changed the program now!
Instead of calculating frequency we changed to working with the period between two pulses.
When a rising edge occurs, we take an interupt to calculate the period.
A switch case compares the value of period T against a set value, and calculates timing.
unsigned long ReadyPeriod = 38; // Speed above start frequency where run can start
unsigned long StartPeriod = 48; // Speed at which timing starts
unsigned long StopPeriod = 77; // Speed at which timing stops
const byte interruptPin = 2;
int counter1 = 0;
volatile unsigned long T, Toud, Tnew;
while (!Serial);
pinMode(interruptPin, INPUT);
attachInterrupt(digitalPinToInterrupt(interruptPin), meting, RISING);
switch (State) {
if (T < ReadyPeriod) {
if (T >= StartPeriod) {
State = RUNNING;
case RUNNING:
if (T >= StopPeriod) {
void meting()
Tnew = millis();
T = Tnew - Toud;
Toud = Tnew;
What do you guys think?
Also, now we measure the period between two pulses but to minimize the fault on our timing we would like to measure the period by taking the mean period of 4 pulses. Since everytime there is a rising edge the interupt runs, I don't see how this would work
an easy way would be to add another volatile variable counting where you are and making the variables in which you capture the timings an array instead of a single value. when the count in 4, in the loop you can calculate the average and reset the count. (whilst then count is at 4, then interrupt would do nothing for example)
J-M-L:
I tried it like this now:
int counter1 = 0;
volatile unsigned long T, Ta, Tb, Tc, Td, Te, Teen, Ttwee, Tdrie, Tvier;
while (!Serial);
T = (Teen + Ttwee + Tdrie + Tvier) / 4;
switch (State) {
State = RUNNING;
case RUNNING:
void meting()
Ta = millis();
Teen = Ta - Tb;
Ttwee = Tb - Tc;
Tdrie = Tc - Td;
Tvier = Td - Te;
Te = Td;
Td = Tc;
Tc = Tb;
Tb = Ta;
And this seems to work. I put the calculation of the average in the loop, because I've heard dividing takes a lot of time and you should keep that away from your interupts.
Do you mean putting the T values in an array, instead of using Ta, Tb, Tc, etc?
void meting()
Ta = millis();
Teen = Ta - Tb;
Ttwee = Tb - Tc;
Tdrie = Tc - Td;
Tvier = Td - Te;
Te = Td;
Td = Tc;
Tc = Tb;
Tb = Ta;
this has NO chance of delivering an average...
you need something that say "if it is the first time I arrive here, record in Ta, second time in Tb, third time in Tc and 4th time in Td... here you end up with all the values being equal.
--> an array and index in the array is what you need
