Décibel avec ICS43434 avec ESP32
Bonjour,
j'essaye de réaliser un décibel mètre avec un esp32.
J'ai trouvé un projet similaire sur internet pour mes besoins , sauf que quand je le téléverse dans ma console, j'ai "nan".
Pourriez vous m'aidez ?
Voici le programme :
#include <driver/i2s.h>
#include "sos-iir-filter.h"
// Configuration
#define LEQ_PERIOD        1           // second(s)
#define WEIGHTING         C_weighting // Also avaliable: 'C_weighting' or 'None' (Z_weighting)
#define LEQ_UNITS         "LAeq"      // customize based on above weighting used
#define DB_UNITS          "dBA"       // customize based on above weighting used
// NOTE: Some microphones require at least DC-Blocker filter
#define MIC_EQUALIZER     ICS43434    // See below for defined IIR filters or set to 'None' to disable
#define MIC_OFFSET_DB     3.0103      // Default offset (sine-wave RMS vs. dBFS). Modify this value for linear calibration
// Customize these values from microphone datasheet
#define MIC_SENSITIVITY   -26         // dBFS value expected at MIC_REF_DB (Sensitivity value from datasheet)
#define MIC_REF_DB        94.0        // Value at which point sensitivity is specified in datasheet (dB)
#define MIC_OVERLOAD_DB   116.0       // dB - Acoustic overload point
#define MIC_NOISE_DB      29          // dB - Noise floor
#define MIC_BITS          24          // valid number of bits in I2S data
#define MIC_CONVERT(s)    (s >> (SAMPLE_BITS - MIC_BITS))
#define MIC_TIMING_SHIFT  0           // Set to one to fix MSB timing for some microphones, i.e. SPH0645LM4H-x
// Calculate reference amplitude value at compile time
constexpr double MIC_REF_AMPL = pow(10, double(MIC_SENSITIVITY)/20) * ((1<<(MIC_BITS-1))-1);
// I2S pins - Can be routed to almost any (unused) ESP32 pin.
//            SD can be any pin, inlcuding input only pins (36-39).
//            SCK (i.e. BCLK) and WS (i.e. L/R CLK) must be output capable pins
// Below ones are just example for my board layout, put here the pins you will use
#define I2S_WS            4
#define I2S_SCK           16
#define I2S_SD            17
// I2S peripheral to use (0 or 1)
#define I2S_PORT          I2S_NUM_0
// IIR Filters
// DC-Blocker filter - removes DC component from I2S data
// See: https://www.dsprelated.com/freebooks/filters/DC_Blocker.html
// a1 = -0.9992 should heavily attenuate frequencies below 10Hz
SOS_IIR_Filter DC_BLOCKER = {
  gain: 1.0,
  sos: {{-1.0, 0.0, +0.9992, 0}}
// Equalizer IIR filters to flatten microphone frequency response
// See respective .m file for filter design. Fs = 48Khz.
// Filters are represented as Second-Order Sections cascade with assumption
// that b0 and a0 are equal to 1.0 and 'gain' is applied at the last step
// B and A coefficients were transformed with GNU Octave:
// [sos, gain] = tf2sos(B, A)
// See: https://www.dsprelated.com/freebooks/filters/Series_Second_Order_Sections.html
// NOTE: SOS matrix 'a1' and 'a2' coefficients are negatives of tf2sos output
// TDK/InvenSense ICS-43434
// Datasheet: https://www.invensense.com/wp-content/uploads/2016/02/DS-000069-ICS-43434-v1.1.pdf
// B = [0.477326418836803, -0.486486982406126, -0.336455844522277, 0.234624646917202, 0.111023257388606];
// A = [1.0, -1.93073383849136326, 0.86519456089576796, 0.06442838283825100, 0.00111249298800616];
SOS_IIR_Filter ICS43434 = {
  gain: 0.477326418836803,
  sos: { // Second-Order Sections {b1, b2, -a1, -a2}
   {+0.96986791463971267, 0.23515976355743193, -0.06681948004769928, -0.00111521990688128},
   {-1.98905931743624453, 0.98908924206960169, +1.99755331853906037, -0.99755481510122113}
// TDK/InvenSense ICS-43432
// Datasheet: https://www.invensense.com/wp-content/uploads/2015/02/ICS-43432-data-sheet-v1.3.pdf
// B = [-0.45733702338341309   1.12228667105574775  -0.77818278904413563, 0.00968926337978037, 0.10345668405223755]
// A = [1.0, -3.3420781082912949, 4.4033694320978771, -3.0167072679918010, 1.2265536567647031, -0.2962229189311990, 0.0251085747458112]
SOS_IIR_Filter ICS43432 = {
  gain: -0.457337023383413,
    {-0.544047931916859, -0.248361759321800, +0.403298891662298, -0.207346186351843},
    {-1.909911869441421, +0.910830292683527, +1.790285722826743, -0.804085812369134},
    {+0.000000000000000, +0.000000000000000, +1.148493493802252, -0.150599527756651}
// TDK/InvenSense INMP441
// Datasheet: https://www.invensense.com/wp-content/uploads/2015/02/INMP441.pdf
// B ~= [1.00198, -1.99085, 0.98892]
// A ~= [1.0, -1.99518, 0.99518]
SOS_IIR_Filter INMP441 = {
  gain: 1.00197834654696,
    {-1.986920458344451, +0.986963226946616, +1.995178510504166, -0.995184322194091}
// Infineon IM69D130 Shield2Go
// Datasheet: https://www.infineon.com/dgdl/Infineon-IM69D130-DS-v01_00-EN.pdf?fileId=5546d462602a9dc801607a0e46511a2e
// B ~= [1.001240684967527, -1.996936108836337, 0.995703101823006]
// A ~= [1.0, -1.997675693595542, 0.997677044195563]
// With additional DC blocking component
SOS_IIR_Filter IM69D130 = {
  gain: 1.00124068496753,
  sos: {
    {-1.0, 0.0, +0.9992, 0}, // DC blocker, a1 = -0.9992
    {-1.994461610298131, 0.994469278738208, +1.997675693595542, -0.997677044195563}
// Knowles SPH0645LM4H-B, rev. B
// https://cdn-shop.adafruit.com/product-files/3421/i2S+Datasheet.PDF
// B ~= [1.001234, -1.991352, 0.990149]
// A ~= [1.0, -1.993853, 0.993863]
SOS_IIR_Filter SPH0645LM4H_B_RB = {
  gain: 1.00123377961525,
    {-1.988897663539382, +0.988928479008099, +1.993853376183491, -0.993862821429572}
// Weighting filters
// A-weighting IIR Filter, Fs = 48KHz
// (By Dr. Matt L., Source: https://dsp.stackexchange.com/a/36122)
// B = [0.169994948147430, 0.280415310498794, -1.120574766348363, 0.131562559965936, 0.974153561246036, -0.282740857326553, -0.152810756202003]
// A = [1.0, -2.12979364760736134, 0.42996125885751674, 1.62132698199721426, -0.96669962900852902, 0.00121015844426781, 0.04400300696788968]
SOS_IIR_Filter A_weighting = {
  gain: 0.169994948147430,
    {-2.00026996133106, +1.00027056142719, -1.060868438509278, -0.163987445885926},
    {+4.35912384203144, +3.09120265783884, +1.208419926363593, -0.273166998428332},
    {-0.70930303489759, -0.29071868393580, +1.982242159753048, -0.982298594928989}
// C-weighting IIR Filter, Fs = 48KHz
// Designed by invfreqz curve-fitting, see respective .m file
// B = [-0.49164716933714026, 0.14844753846498662, 0.74117815661529129, -0.03281878334039314, -0.29709276192593875, -0.06442545322197900, -0.00364152725482682]
// A = [1.0, -1.0325358998928318, -0.9524000181023488, 0.8936404694728326   0.2256286147169398  -0.1499917107550188, 0.0156718181681081]
SOS_IIR_Filter C_weighting = {
  gain: -0.491647169337140,
  sos: {
    {+1.4604385758204708, +0.5275070373815286, +1.9946144559930252, -0.9946217070140883},
    {+0.2376222404939509, +0.0140411206016894, -1.3396585608422749, -0.4421457807694559},
    {-2.0000000000000000, +1.0000000000000000, +0.3775800047420818, -0.0356365756680430}
// Sampling
#define SAMPLE_RATE       48000 // Hz, fixed to design of IIR filters
#define SAMPLE_BITS       32    // bits
#define SAMPLE_T          int32_t
#define SAMPLES_SHORT     (SAMPLE_RATE / 8) // ~125ms
#define SAMPLES_LEQ       (SAMPLE_RATE * LEQ_PERIOD)
#define DMA_BANK_SIZE     (SAMPLES_SHORT / 16)
#define DMA_BANKS         32
// Data we push to 'samples_queue'
struct sum_queue_t {
  // Sum of squares of mic samples, after Equalizer filter
  float sum_sqr_SPL;
  // Sum of squares of weighted mic samples
  float sum_sqr_weighted;
  // Debug only, FreeRTOS ticks we spent processing the I2S data
  uint32_t proc_ticks;
QueueHandle_t samples_queue;
// Static buffer for block of samples
float samples[SAMPLES_SHORT] __attribute__((aligned(4)));
// I2S Microphone sampling setup
void mic_i2s_init() {
  // Setup I2S to sample mono channel for SAMPLE_RATE * SAMPLE_BITS
  // NOTE: Recent update to Arduino_esp32 (1.0.2 -> 1.0.3)
  //       seems to have swapped ONLY_LEFT and ONLY_RIGHT channels
  const i2s_config_t i2s_config = {
    mode: i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_RX),
    sample_rate: SAMPLE_RATE,
    bits_per_sample: i2s_bits_per_sample_t(SAMPLE_BITS),
    channel_format: I2S_CHANNEL_FMT_ONLY_LEFT,
    communication_format: i2s_comm_format_t(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
    intr_alloc_flags: ESP_INTR_FLAG_LEVEL1,
    dma_buf_count: DMA_BANKS,
    dma_buf_len: DMA_BANK_SIZE,
    use_apll: true,
    tx_desc_auto_clear: false,
    fixed_mclk: 0
  // I2S pin mapping
  const i2s_pin_config_t pin_config = {
    bck_io_num:   I2S_SCK,
    ws_io_num:    I2S_WS,
    data_out_num: -1, // not used
    data_in_num:  I2S_SD
  i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
  #if (MIC_TIMING_SHIFT > 0)
    // Undocumented (?!) manipulation of I2S peripheral registers
    // to fix MSB timing issues with some I2S microphones
    REG_SET_BIT(I2S_TIMING_REG(I2S_PORT), BIT(9));
    REG_SET_BIT(I2S_CONF_REG(I2S_PORT), I2S_RX_MSB_SHIFT);
  #endif
  i2s_set_pin(I2S_PORT, &pin_config);
  //FIXME: There is a known issue with esp-idf and sampling rates, see:
  //       https://github.com/espressif/esp-idf/issues/2634
  //       In the meantime, the below line seems to set sampling rate at ~47999.992Hz
  //       fifs_req=24576000, sdm0=149, sdm1=212, sdm2=5, odir=2 -> fifs_reached=24575996
  //NOTE:  This seems to be fixed in ESP32 Arduino 1.0.4, esp-idf 3.2
  //       Should be safe to remove...
  //#include <soc/rtc.h>
  //rtc_clk_apll_enable(1, 149, 212, 5, 2);
// I2S Reader Task
// Rationale for separate task reading I2S is that IIR filter
// processing cam be scheduled to different core on the ESP32
// while main task can do something else, like update the
// display in the example
// As this is intended to run as separate hihg-priority task,
// we only do the minimum required work with the I2S data
// until it is 'compressed' into sum of squares
// FreeRTOS priority and stack size (in 32-bit words)
#define I2S_TASK_PRI   4
#define I2S_TASK_STACK 2048
void mic_i2s_reader_task(void* parameter) {
  mic_i2s_init();
  // Discard first block, microphone may have startup time (i.e. INMP441 up to 83ms)
  size_t bytes_read = 0;
  i2s_read(I2S_PORT, &samples, SAMPLES_SHORT * sizeof(int32_t), &bytes_read, portMAX_DELAY);
  while (true) {
    // Block and wait for microphone values from I2S
    // Data is moved from DMA buffers to our 'samples' buffer by the driver ISR
    // and when there is requested ammount of data, task is unblocked
    // Note: i2s_read does not care it is writing in float[] buffer, it will write
    //       integer values to the given address, as received from the hardware peripheral.
    i2s_read(I2S_PORT, &samples, SAMPLES_SHORT * sizeof(SAMPLE_T), &bytes_read, portMAX_DELAY);
    TickType_t start_tick = xTaskGetTickCount();
    // Convert (including shifting) integer microphone values to floats,
    // using the same buffer (assumed sample size is same as size of float),
    // to save a bit of memory
    SAMPLE_T* int_samples = (SAMPLE_T*)&samples;
    for(int i=0; i<SAMPLES_SHORT; i++) samples[i] = MIC_CONVERT(int_samples[i]);
    sum_queue_t q;
    // Apply equalization and calculate Z-weighted sum of squares,
    // writes filtered samples back to the same buffer.
    q.sum_sqr_SPL = MIC_EQUALIZER.filter(samples, samples, SAMPLES_SHORT);
    // Apply weighting and calucate weigthed sum of squares
    q.sum_sqr_weighted = WEIGHTING.filter(samples, samples, SAMPLES_SHORT);
    // Debug only. Ticks we spent filtering and summing block of I2S data
    q.proc_ticks = xTaskGetTickCount() - start_tick;
    // Send the sums to FreeRTOS queue where main task will pick them up
    // and further calcualte decibel values (division, logarithms, etc...)
    xQueueSend(samples_queue, &q, portMAX_DELAY);
// Setup and main loop
// Note: Use doubles, not floats, here unless you want to pin
//       the task to whichever core it happens to run on at the moment
  // If needed, now you can actually lower the CPU frquency,
  // i.e. if you want to (slightly) reduce ESP32 power consumption
  setCpuFrequencyMhz(80); // It should run as low as 80MHz
  Serial.begin(112500);
  delay(1000); // Safety
  // Create FreeRTOS queue
  samples_queue = xQueueCreate(8, sizeof(sum_queue_t));
  // Create the I2S reader FreeRTOS task
  // NOTE: Current version of ESP-IDF will pin the task
  //       automatically to the first core it happens to run on
  //       (due to using the hardware FPU instructions).
  //       For manual control see: xTaskCreatePinnedToCore
  xTaskCreate(mic_i2s_reader_task, "Mic I2S Reader", I2S_TASK_STACK, NULL, I2S_TASK_PRI, NULL);
  sum_queue_t q;
  uint32_t Leq_samples = 0;
  double Leq_sum_sqr = 0;
  double Leq_dB = 0;
  // Read sum of samaples, calculated by 'i2s_reader_task'
  while (xQueueReceive(samples_queue, &q, portMAX_DELAY)) {
    // Calculate dB values relative to MIC_REF_AMPL and adjust for microphone reference
    double short_RMS = sqrt(double(q.sum_sqr_SPL) / SAMPLES_SHORT);
    double short_SPL_dB = MIC_OFFSET_DB + MIC_REF_DB + 20 * log10(short_RMS / MIC_REF_AMPL);
    // In case of acoustic overload or below noise floor measurement, report infinty Leq value
    if (short_SPL_dB > MIC_OVERLOAD_DB) {
      Leq_sum_sqr = INFINITY;
    } else if (isnan(short_SPL_dB) || (short_SPL_dB < MIC_NOISE_DB)) {
      Leq_sum_sqr = -INFINITY;
    // Accumulate Leq sum
    Leq_sum_sqr += q.sum_sqr_weighted;
    Leq_samples += SAMPLES_SHORT;
    // When we gather enough samples, calculate new Leq value
    if (Leq_samples >= SAMPLE_RATE * LEQ_PERIOD) {
      double Leq_RMS = sqrt(Leq_sum_sqr / Leq_samples);
      Leq_dB = MIC_OFFSET_DB + MIC_REF_DB + 20 * log10(Leq_RMS / MIC_REF_AMPL);
      Leq_sum_sqr = 0;
      Leq_samples = 0;
      // Serial output, customize (or remove) as needed
      Serial.printf("%.1f\n", Leq_dB);
      // Debug only
      //Serial.printf("%u processing ticks\n", q.proc_ticks);
  // Nothing here..
Bonjour @oaxsim
Nan = not a number.... reste à repérer l'endroit où se produit la chose....le code est 'pointu'
peut être au niveau de l'acquisition du signal I2S,
Perso : je n'ai pas rencontré ce pb avec ma réalisation basée sur le même code, à l'affichage près, présenté ici sur le forum : Sonometre connecté (ESP32+ micro I2S)
Source du projet : https://github.com/ikostoski/esp32-i2s-slm
Il n'existe pas un petit programme pour avoir juste le DB ?
Obligé des programmes xxl ? car pour les comprendre c'est impossible pour moi .
le calcul des dB pondérés (dBA par exemple) en jeu des filtres de bandes et ça complique nécessairement le code. C'est le cas du code que tu cherches à utilisé. Pour ma part ce code est tombé à pic, il me fallait des dBA pour avoir une indication comparable à celle d'un véritable sonomètre.
Et le projet trouvé fait un sacré travail !!
https://raw.githubusercontent.com/ikostoski/esp32-i2s-slm/master/misc/esp32-i2s-slm-bp.svg
Il ya sans doute du code plus simple si l'on ne cherche pas à 'coller' aux pondérations usuelles
il suffit , à priori, de récupérer la valeur brute arrivant du micro par le bus I2S puis convertir en dB avec la sensibilité du micro annoncée par le fabricant du capteur
Voir par exemple ce que propose Adafruit pour le modèle de microphone I2S qu'il vend :
https://learn.adafruit.com/adafruit-i2s-mems-microphone-breakout/arduino-wiring-and-test
par hasard tu ne sais pas si il y a un autre capteur avec une librairie ou un programme déjà fait qui m'affiche mes données dans la console ?
Car je n'arrive pas à trouver l'erreur dans mon programme, c'est possible que ce soit le capteur (ics-43434) qui ne fonctionne plus ? ou pas ?
OU : lances 'test INMP441 Arduino' dans ton moteur de recherche, tu tomberas sur des vidéos avec du code simple de test , qui très probablement fonctionnent avec ton micro I2S (une version plus récente du INMP441)
c'est possible que ce soit le capteur (ics-43434) qui ne fonctionne plus ? ou pas ?est
oui , c'est tout à fait possible
J'ai regardé mais à chaque fois il regarde les courbes et pas les DB. moi je veux juste les db affiché sur ma console, après je les afficherai sur mon écran TFT.
Tu sais comment je peux voir si mon capteur ne fonctionne plus ?
Commences par tester ton micro en affichant une courbe., avec le code existant
Le calcul des dB sera a régler ensuite( logarithme d'un rapport)
Vu que j'ai que des "nan" dans la console j'ai rien dans le traceur série
Avec du code très simple de test ou avec le code complexe du sonomètre en dBA ?
code complexe , je n'ai pas de code simple
Pour du code simple de test de micros I2S j'ai donné des, pistes plus haut , en laissant de côté les dB dans un premier temps pour se contenter de vérifier que le mucro sorte bien en permanence un nombre reflétant la pression accoustique.
ok, j'ai trouvé ce programme exemple de l'i2s
Tu peux me dire ou je déclare WS , SD , sck stp
 * This is an example to read analog data at high frequency using the I2S peripheral
 * Run a wire between pins 27 & 32
 * The readings from the device will be 12bit (0-4096)
#define I2S_SAMPLE_RATE 78125
#define ADC_INPUT ADC1_CHANNEL_4 //pin 32
#define OUTPUT_PIN 27
#define OUTPUT_VALUE 3800
#define READ_DELAY 9000 //microseconds
uint16_t adc_reading;
void i2sInit()
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_ADC_BUILT_IN),
    .sample_rate =  I2S_SAMPLE_RATE,              // The format of the signal using ADC_BUILT_IN
    .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT, // is fixed at 12bit, stereo, MSB
    .channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
    .communication_format = I2S_COMM_FORMAT_I2S_MSB,
    .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
    .dma_buf_count = 4,
    .dma_buf_len = 8,
    .use_apll = false,
    .tx_desc_auto_clear = false,
    .fixed_mclk = 0
   i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);
   i2s_set_adc_mode(ADC_UNIT_1, ADC_INPUT);
   i2s_adc_enable(I2S_NUM_0);
void reader(void *pvParameters) {
  uint32_t read_counter = 0;
  uint64_t read_sum = 0;
// The 4 high bits are the channel, and the data is inverted
  uint16_t offset = (int)ADC_INPUT * 0x1000 + 0xFFF;
  size_t bytes_read;
  while(1){
    uint16_t buffer[2] = {0};
    i2s_read(I2S_NUM_0, &buffer, sizeof(buffer), &bytes_read, 15);
    //Serial.printf("%d  %d\n", offset - buffer[0], offset - buffer[1]);
    if (bytes_read == sizeof(buffer)) {
      read_sum += offset - buffer[0];
      read_sum += offset - buffer[1];
      read_counter++;
      Serial.println("buffer empty");
    if (read_counter == I2S_SAMPLE_RATE) {
      adc_reading = read_sum / I2S_SAMPLE_RATE / 2;
      //Serial.printf("avg: %d millis: ", adc_reading);
      //Serial.println(millis());
      read_counter = 0;
      read_sum = 0;
      i2s_adc_disable(I2S_NUM_0);
      delay(READ_DELAY);
  // Put a signal out on pin
  uint32_t freq = ledcSetup(0, I2S_SAMPLE_RATE, 10);
  Serial.printf("Output frequency: %d\n", freq);
  ledcWrite(0, OUTPUT_VALUE/4);
  ledcAttachPin(OUTPUT_PIN, 0);
  // Initialize the I2S peripheral
  i2sInit();
  // Create a task that will read the data
  xTaskCreatePinnedToCore(reader, "ADC_reader", 2048, NULL, 1, NULL, 1);
  delay(1020);
  Serial.printf("ADC reading: %d\n", adc_reading);
  delay(READ_DELAY);
Je ne saisis pas bien le but de ce programme où je vois plutôy l'I2S en sortie pas en entrée pour visualiser ce qu'envoie un micro.
Ducoup j'ai trouvé ce programme :
J'ai bien modifié sck en 16 et sd en 17 et ws en 4
tu en pense quoi ?
j'obtient ça
// you shouldn't need to change these settings
#define SAMPLE_BUFFER_SIZE 512
#define SAMPLE_RATE 8000
// most microphones will probably default to left channel but you may need to tie the L/R pin low
#define I2S_MIC_CHANNEL I2S_CHANNEL_FMT_ONLY_LEFT
// either wire your microphone to the same pins or change these to match your wiring
#define I2S_MIC_SERIAL_CLOCK GPIO_NUM_16
#define I2S_MIC_LEFT_RIGHT_CLOCK GPIO_NUM_4
#define I2S_MIC_SERIAL_DATA GPIO_NUM_17
// don't mess around with this
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX),
    .sample_rate = SAMPLE_RATE,
    .bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT,
    .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
    .communication_format = I2S_COMM_FORMAT_I2S,
    .dma_buf_count = 4,
    .dma_buf_len = 1024,
    .use_apll = false,
    .fixed_mclk = 0};
// and don't mess around with this
i2s_pin_config_t i2s_mic_pins = {
    .bck_io_num = I2S_MIC_SERIAL_CLOCK,
    .ws_io_num = I2S_MIC_LEFT_RIGHT_CLOCK,
    .data_out_num = I2S_PIN_NO_CHANGE,
    .data_in_num = I2S_MIC_SERIAL_DATA};
  // we need serial output for the plotter
  // start up the I2S peripheral
  i2s_set_pin(I2S_NUM_0, &i2s_mic_pins);
int32_t raw_samples[SAMPLE_BUFFER_SIZE];
  // read from the I2S device
  i2s_read(I2S_NUM_0, raw_samples, sizeof(int32_t) * SAMPLE_BUFFER_SIZE, &bytes_read, portMAX_DELAY);
  int samples_read = bytes_read / sizeof(int32_t);
  // dump the samples out to the serial channel.
  for (int i = 0; i < samples_read; i++)
    Serial.printf("%ld\n", raw_samples[i]);
1)je ne maîtrise pas assez l'I2S sur ESP32 pour penser de ça quelquechose de constructif !!
juste une question : que fais-tu de la pin L/R du micro ?...dans le code tu indiques au driver I2S de s'intéresser à la voie gauche dans le signal stereo I2S(only_left). Sur o montage L est reliée à la masse pour s'assurer que le micro I2S (mono) est configuré en 'canal Gauche'?
2)je ne suis pas en situation de faire des tests pour proposer quelquechose de vérifié
proposition :
Va sur vette page : https://diyi0t.com/i2s-sound-tutorial-for-esp32/
vois la partie nommée "How to Record and Visualize Data with an I2S Microphone"
câblesdans un premiet temps comme indiqué sur le dessin et dans le code
si c'est OK tu peux ensuite tenter de modifier les GPIOs.... dans les limites de ce que l'ESP32 permet de faire...
Ducoup toujours pareil, j'ai regardé ton lien : Arduino Wiring & Test | Adafruit I2S MEMS Microphone Breakout | Adafruit Learning System
Mais c'est pas écrit si c'est compatible avec un esp32.
Tu ne connais pas un truc tout prêt? je lance le programme exemple et c'est bon ?
Avec INMP441 c'est combien le nombre de DB max réel
tua s raison , je n'ai pas érifié la compatibilité ESP32 pour le lien Adafruit
pr contre la référence que j'ai indiqué au message#17 est pour ESP32
INMP441 , dans les 90dB maxi il me semble peut être plus en pointe (il faudrait éplucher la Data Sheet pour s'en assurer)
D'accord ton message #17, c'est la même carte que adafruit ( Arduino Wiring & Test | Adafruit I2S MEMS Microphone Breakout | Adafruit Learning System ) donc je dirai que c'est compatible même si il ne le dise pas nn ?
en #17 un micro I2S Adafruit à base de SPH0645 est monté sur un ESP32
je ne suis aps en mesure d'ici quelques joures de tester ce code avec un INMP441., je m'attend à ce qu'un signal soit visible dans le traceur.
avec un ICS43434 aussi.4
(sauf erreur de compréhension de ma part ces divers microphones I2S n'ont pas besoin d'être configurés, ils sortent les données au rythme de l'horloge + pas d'adressse comme dans le cas de l'I2C.....)
