Decimal Places
Hi All,
I'm outputting the float value of "temperature" to a LCD & my phone from an ATMega, value is currently displayed as xx.xxx.
How can I change this so it only shows xx?
Many thanks,
Mick.
.print (, 2);
(deleted)
CtrlAltElite:
.print (, 2);
Thank you for your reply but that might as well be in dutch as far as I'm concerned.
mickjbriggs:
Well, you didn't post any of your code, so it was the best I could do.
spycatcher2k:
With no rounding - Serial.print(int(temperature));
With rounding - Serial.print(int(temperature + 0.5));
Thank you for your reply but that doesn't work, it adds decimal places.
CtrlAltElite:
Fair point,
I was emphasising my lack of knowledge, I didn't intend to be rude.
The relevant bit of code is:
int tempRaw = analogRead(tempPin);
float temp = (tempRaw/1024.0) *5.0;
float temperature = (temp - .5) * 100;
Blynk.virtualWrite(V0, temperature);
I'm sorry, I have no idea what a "Blynk" is, but the Arduino print methods allow you to specify how many decimal places to print - the default is two.
Should be:
float temperature = (temp - 0.5) * 100;
Post the code that prints to the LCD.
outsider:
Should be:
What's the difference? (Apart from the obvious, redundant leading zero)
outsider:
Should be:
Thanks for your reply but that makes no difference.
LCD code is irrelevant as its only displaying the same value.
I think you should take a closer look at this Blynk thing - perhaps the documentation can help you.
CtrlAltElite:
I don't think it has anything to do with the Blynk app, it is only displaying the same value that I have on my LCD & is "printed" to serial monitor.
mickjbriggs:
Well, maybe we're missing what you think isn't the relevant bits of the code.
CtrlAltElite:
Possible:
/* Comment this out to disable prints and save space */
//#define BLYNK_PRINT Serial
#include <ESP8266_Lib.h>
#include <BlynkSimpleShieldEsp8266.h>
const int tempPin = A0;
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "nothing to see here";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "xxxxxxxxx";
char pass[] = "yyyyyyyy";
// Hardware Serial on Mega, Leonardo, Micro...
//#define EspSerial Serial1
// or Software Serial on Uno, Nano...
#include <SoftwareSerial.h>
SoftwareSerial EspSerial(A4, A5); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 19200
ESP8266 wifi(&EspSerial);
BlynkTimer timer;
// This function sends Arduino's up time every second to Virtual Pin (5).
// In the app, Widget's reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void myTimerEvent()
// You can send any value at any time.
// Please don't send more that 10 values per second.
Blynk.virtualWrite(V1, millis() / 1000);
void temperature()
// Debug console
// Set ESP8266 baud rate
EspSerial.begin(ESP8266_BAUD);
delay(10);
Blynk.begin(auth, wifi, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
// Setup a function to be called every second
timer.setInterval(1000L, myTimerEvent);
timer.setInterval(1000L, temperature);
Blynk.run();
timer.run(); // Initiates BlynkTimer
Blynk.virtualWrite(V0, temperature,0);
cherk:
Nope, doesn't work but thanks any way.
dtostrf() it to a c-string with the precision you want and then send it to Blynk.
gfvalvo:
Or, set the number of decimals to display on the Virtual Pin in the Blynk app.
Really? That SHOULD work; it should convert the float value to an integer, which should then be displayed without a decimal point. Unless int() is weird on you board (try Serial.print((long)(temperature+0.5)):wink: Or unless the Blynk device only displays floats...
