Decimal point in serial communication
I'm learning serial communication from PC to Uno. My circuit simply has an LED & limiting resistor connected to digital pin 9. If I enter 55 in the serial monitor the Uno turns on the LED and tells me that I entered 55. The code below works for that. If I change the code to look for 5.5, i.e. I put a decimal in the number the code fails. I receive two responses in the serial monitor - each tells me that my number is 5. How can I get the Uno to recognize a decimal point?
float myNumber;
int ledPin=9;
String msg="Please Enter Your Number:";
String msg2="Your Number Is: ";
pinMode(ledPin,OUTPUT);
Serial.println(msg);
while (Serial.available()==0){
myNumber=(Serial.parseInt());
Serial.print(msg2);
Serial.println(myNumber);
if(myNumber==55)
digitalWrite(ledPin, HIGH);
In the more general case when you want to handle a line input and parse it yourself, have a look at Serial Input Basics to handle this in a good asynchronous way
Attention to detail is what it takes :slight_smile: Thanks
