The real fun begins when the students are told, "okay, now do it without using print()". ![]()
Blink Morse on LED_BUILTIN
Hello again,
I have modified my code, it gives the right "answer" but i tried to implement a line to print the value before it's conversion ... but it gives a stupid value and not what i entered ![]()
int incomingByte = 0;
// envoie une donnée sur le port série seulement quand reçoit une donnée
if (Serial.available() > 0)
// si données disponibles sur le port série
// lit l'octet entrant
incomingByte = Serial.read();
// renvoie l'octet reçu
Serial.print(incomingByte);
Serial.print('\t'); // affiche un tab
Serial.print("Base 2 -> ");
Serial.println(incomingByte - '0', BIN);
In this case, i tried:
5
6
7
8
and it returns
53
54
55
56
Any idea ?
The ASCII code for '0' is 48, for '1' it's 49, for '2' it's 50...
See the pattern?
yeah ...
is there a way to get rid of that char equivalent ?
Yes - see my earlier post that you marked as the solution.
That's what i did but it doesn't change anything ![]()
You only did half the job.
aaaahhh .
I see, it works now, thanks !
And now, if you put that code into a function, you only need to do the subtraction once.
Hi @louis_f
You said this was a school assignment.
Which school course are you attending?
RV mineirin
Turns out that the teacher didn't want it this way but with Euclidean division.
have to start all over again and i have to hand it in for tonight ![]()
Anyway, thanks for your help ^^
I doubt that very much. The only thing you need to change is the print method.
What is your time zone?
Do you still have time to redo?
Try it like this:
Serial.println(incomingByte%48,BIN);
%48 is a division by 48 and the printout shows the rest.
RV mineirin
@RV, I believe they've been asked to do the base 2 conversion "the hard way". Your solution would be rejected by the professor.
@anon57585045
In theory an Euclidean division is an A/B split.
the rest r is part of the Euclidean division.
Therefore A = inputByte
B = 48 (divider).
And the impression is the rest r.
RV mineirin
I doubt very much that the course would have you use a computationally intensive operator to perform a simple subtraction that takes 63.5 nanoseconds to complete.
I'm sure that the Euclidean division that the professor requested, is for the result A, which when divided by B = 2, produces the remainder r which is one binary digit of the result.
Hi @anon57585045 i @
BTW, I think the time has passed.
Student "timer over".
RV mineirin
