decimal to whole number
I’m new here, sorry if this is in the wrong spot or anything. anyway, I have a decimal number that i need to turn into a whole number.
my temp comes out as decimal and i need it to be a whole number. any help would be great, thank you :slight_smile:
#include <LiquidCrystal.h>
#include <math.h>
double Thermister(int RawADC) {
	double Temp;
	Temp = log(((10240000/RawADC) - 10000));
	Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
	Temp = Temp - 273.15; // Convert Kelvin to Celcius
        Temp = (Temp * 9.0)/ 5.0 + 32.0; // Convert Celcius to Fahrenheit
        Temp = (Temp - 3);
	return Temp;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  Serial.begin(9600); // serial monitor
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.clear(); //clear screen
  lcd.print(Thermister(analogRead(0))); //print temp
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print second line
  lcd.print("Temp");
moderator: added code tags
Do you want to truncate the value or round it?
either way is fine, it dont have to be spot on.
Considering the accuracy that you are trying to work to in
I find that quite amusing
lol i just want a simple temp read out, no decimals :slight_smile:
Just assign the floating point value to an integer variable. This will truncate.
If you want to round, add a half before the assignment.
how do i do that? sorry im new to this :slight_smile:
float flt = 123.6745;
int noDec = 0;
noDec = flt; // = 123, truncated
noDec = flt + 0.5; // = 124, rounded
flt = 123.456 ;
noDec = flt + 0.5; // = 123, rounded
lcd.print(Thermister(analogRead(0)), 0); // print temp with zero decimal places
THANK YOU! it worked! :slight_smile:
There are four functions to help you with different versions of rounding floats.
Try this snippet of code to spot the differences
for (int i= -5; i < 5; i++)
  float flt = i + 0.45;
  int x1 = round(flt);    // rounding
  int x2 = ceil(flt);     // round up
  int x3 = floor(flt);    // round down
  int x4 = trunc(flt);    // remove decimal part
  int x5 = flt;           // implicit
  Serial.print(x1);
  Serial.print('\t');
  Serial.print(x2);
  Serial.print('\t');
  Serial.print(x3);
  Serial.print('\t');
  Serial.print(x4);
  Serial.print('\t');
  Serial.print(x5);
