decimal values in CHAR to FLOAT
Hello,
I have temperature value stored in an array. (e.g. 37,3) as when I dump locations from 0 to 3, I’ll get 51,55,46 and 51 in decimal.
I need to convert those into a float in order to further process them, but I always loose the decimal value on the way.
This is a huge project and to give you an idea, I’ve included some code.
void loaddefaults()
byte value;
  for(int sayman=0; sayman< 30; sayman++) //
       value = EEPROM.read(sayman);
       epromstring[sayman] = value;
      Serial.println("displaying value of epromstring :");
      Serial.println(epromstring[sayman]);
      Serial.println("---------------------------");
Result:
3
7
2
So, I’m sure that data is in including decimal point and data.
Now, When I convert like so,
char epromstring[30];
float minderece;
minderece == epromstring[0]+epromstring[1]+ epromstring[2] + epromstring[3];
Serial.println(minderece);
Result is 37.00
Please note that all data stored is in the same format, that is to say, xx,x.
Is there a way to pass data including decimal into float ?
Thank you.
Please use code tags.
Read this before posting a programming question
You could use "atof", but I'm not sure how it would handle the comma, and you'd have to make sure you have a proper C-style string. Or, you could simply store the float in the EEPROM as a float in the first place.
The atof() function would work of the decimal point was not a comma.
If it is stored as xx,x
then not only are you adding the ascii value of ',' but you are adding the decimal part as if it were a whole number. You would end up adding 3 + 7 + 44 + 2, which is not 37...
Perhaps?
minderece == (epromstring[0]*10) + epromstring[1] + (float)(epromstring[3]/10);
