Decimals?
I am doing a project which rounds microsecond pulses(1000-2000). I have decided that the best way to round them is to divide them by 1000 and round the decimal, then multiply them by 1000. What is a varible that can work with decimals but is also precise?
I tried using int, it gave me 0s 1s and 2s
I tried using float, which gave me 0.00 1.00 and 2.00
These some examples of the pulses that I was dividing by 1000 were
1540
1558
1562
1475
1558
1562
1540
1558
1540
Is there a way I could get the quotient of the numbers to be 1.54 1.558 1.562 etc?
Thanks!
DPduino88:
Most likely you DO NOT want to do an "integer division" by 1000, but perhaps you want to do a "float division" by a float divisor 1000.0 instead integer divisor 1000?
that's because you probably did integer maths and stored the result in the float
int x = 1540;
float f0 = x / 1000; // --> the compiler will calculate the right side as integer math, so truncates
float f1 = x / 1000.0; // the .0 changes everything, the compiler will compute the right side as float
float f2 = ((float) x) / 1000; // would work too. compiler will use float calculation as soon as one member is floating point
float f3 = ((float) x) / 1000.0; //of courseĀ  would work too
DO NOT CROSS POST!
Mark
