Deciphering RF Codes. (!= error???)
I have 2 arduino's connected via RF. There are 2 buttons on one and 3 LED's on the other. One LED stays on verifying connection. When button1 is pushed LED2 stays on, when button2 is pushed LED3 flashes.
I have this broken down as such, when button1 is pushed, it sends a 6 digit code to the LED arduino. When button 2 is pushed it sends another code to the LED arduino. I can see the codes in the serial monitor.
I am trying to put together a garage door monitor (dang kid leaves it up). I want to know I have a connection to the RF unit, when it is up (button1) or when it is down (button2). The other applications for this code would be amazing and I'd love to share. I have searched all over the googles and youtubes but they mostly all use virtual wire or don't use multiple buttons to send codes for specific pins. I found one example out there that seemed close to what I'm trying to achieve but it was in .hex and I couldn't get it to open in visual studio.
Transmitter:
#include <RH_ASK.h>
#include <SPI.h> // Not actually used but needed to compile
// tx/rx configuration
const int txSpeed = 2000;
const int rxPin = 5;
const int txPin = 6;
const int pttPin = 7;
const int buttonPin1 = 2;     // the number of the pushbutton pin
const int buttonPin2 = 3;     // the number of the pushbutton pin
int buttonState = 0;         // variable for reading the pushbutton status
RH_ASK driver(txSpeed, rxPin, txPin, pttPin);
        if (!driver.init())
    Serial.println("rf driver init failed");
    pinMode(LED_BUILTIN, OUTPUT);
    pinMode(buttonPin1, INPUT);
    pinMode(buttonPin2, INPUT);
   buttonState = digitalRead(buttonPin1);
   if (buttonState == HIGH)
   {    // turn LED on:
    const char *msg1 = "349516";
    driver.send((uint8_t *)msg1, strlen(msg1));
    driver.waitPacketSent();
    delay(20);
   buttonState = digitalRead(buttonPin2);
   {    // turn LED on:
   const char *msg2 = "654321";
    driver.send((uint8_t *)msg2, strlen(msg2));
    delay(20);
Receiver:
#include <RH_ASK.h>
#include <SPI.h> // Not actualy used but needed to compile
int ledPin3 = 3;
int ledPin4 = 4;
int ledPin5 = 8;
int val1 = 349516;
int val2 = 135790;
  Serial.begin(9600);  // Debugging only
  if (!driver.init())
    Serial.println("init failed");
    pinMode(ledPin4, OUTPUT);
    pinMode(ledPin3, OUTPUT);
    pinMode(ledPin5, OUTPUT);
  uint8_t buf[RH_ASK_MAX_MESSAGE_LEN] = {0};
  uint8_t buflen = sizeof(buf);
  if (driver.recv(buf, &buflen)) {// if message received, save it
  for(int i=0;i<sizeof(buf);i++) {
  Serial.println((char*)buf); // print received message, used for debugging.
 if(buf[0] != 654321){ // and if the first letter in message array is X
       digitalWrite(ledPin4,HIGH);
       digitalWrite(ledPin4,LOW);
     if(buf[0] != 349516){ // and if the first letter in message array is X
       digitalWrite(ledPin3,HIGH);
       digitalWrite(ledPin3,LOW);
    else if(buf[0]!= 000000){
     digitalWrite(ledPin5,HIGH);
There seems to be an issue with the loop. I believe don't have the correct code here: if(buf[0] != 654321
What really happens, is the loop happens no matter which code is received: 654321 or 349516.
if(buf[0] != 654321) {"buf" is a character array, and buf[0] is the first byte in that array. Consequently, its value can only be between 0 and 255.
If you want to compare character arrays (also called C-strings), one method would be to use the function strcmp().
If you want to compare single ASCII characters stored in the array, then something like the following will work:
if(buf[0] != '6') {
