Declaration for a set of code.
I was wondering if it was possible to give a chunk of code(specifically a chunk of code to run ultrasonic sensors), a name and declare it as a variable.
here is my code:
#define trigPin1 11
#define echoPin1 12
long duration, distance, RightSensor,BackSensor,FrontSensor,LeftSensor;
Serial.begin (9600);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
SonarSensor(trigPin1, echoPin1);
RightSensor = distance;
int SensVala = Serial.println(RightSensor);
void SonarSensor(int trigPin,int echoPin)
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
Please edit your post and use code tags for the code
Type
** **[code]** **
before the code
Type
** **[/code]** **
after the code
I think what you want is a function that returns a value. Looking at this
void SonarSensor(int trigPin, int echoPin)
  distance = (duration / 2) / 29.1;
you're only interested in the distance. You're function can return the distance.
  read sonar distance
  input:
    trigger pin
    echo pin
  returns:
    distance in cm
long SonarSensor(int trigPin, int echoPin)
Next you can do the calculation as you did
  read sonar distance
  returns:
    distance in cm
  // return measured distance
  return distance;
And in e.g. loop()
  // get the distance
  RightSensor = SonarSensor(trigPin1, echoPin1);
  Serial.print("distance = "); Seral.println(RightSensor);
Now I would clean the function up a little. Nowhere in your code you will be interested in the duration. So instead of making that a global variable, you can declare it inside the function (local variable).
  // variable to hold measured duration
  long duration;
  return distance;
And remove the duration from the global variables near the top of the code.
#define trigPin1 11
#define echoPin1 12
//WAS: long duration, distance, RightSensor, BackSensor, FrontSensor, LeftSensor;
long distance, RightSensor, BackSensor, FrontSensor, LeftSensor;
You can do the same for distance; I would make it a local variable in the SonarSensor function and get rid of it in the global section.
Note
At the moment that you start numbering variables (e.g. trigPin1), it's time to consider arrays.
  long duration;
  return distance;
Fail! void functions do not have return statements.
Thanks for the correction :slight_smile: Fixed it
