Declare a time check function.
Hi guys,
For simplicity consider a rather simple state machine with a button and LEDs: A single button press should light up an LED and after a specific ammount of time the LED should automatically turn off. In fact this works if I write the condition in the loop() like this:
if (millis()-t1>=timeLimit){
    digitalWrite(L1,0);
  if (millis()-t2>=timeLimit){
    digitalWrite(L2,0);
  if (millis()-t3>=timeLimit){
    digitalWrite(L3,0);
t1, t2, and t3 are assigned the sketch uptime 'millis()' at the time the button was pressed.
I want to declare a function just to reduce the size of my loop() function. I tried to declare this function:
void timeCheck()
  millis();
    digitalWrite(L1,0);
    digitalWrite(L2,0);
    digitalWrite(L3,0);
and call it in the loop() function, but by doing so, the LEDs won't light up.
Any ideas on what I'm missing or doing wrong?
Thanks for your help.
Let's see all your code.
LarryD:
Sure. Here it is:
int buttonPIN=2; //Button
int L1=6; //LED 1
int L2=5; // LED 2
int L3=4; // LED 3
int buttonPushCounter = 0;
int buttonState = 0;
int lastButtonState = 0;
unsigned long t1=0;
unsigned long t2=0;
unsigned long t3=0;
unsigned long timeLimit = 2500; //The time after each LED should turn off
  pinMode(L1, OUTPUT);
  pinMode(L2, OUTPUT);
  pinMode(L3, OUTPUT);
  pinMode(buttonPIN, INPUT);
  buttonState = digitalRead(buttonPIN);
  if (buttonState == 1 && lastButtonState==0)
    buttonPushCounter++;
    switch(buttonPushCounter)
    case 1:
      digitalWrite(L1,1);
      t1=millis();
    case 2:
      digitalWrite(L2,1);
      t2=millis();
    case 3:
      digitalWrite(L3,1);
      t3=millis();
      buttonPushCounter=0;
  lastButtonState = buttonState;
    digitalWrite(L1,0);
    digitalWrite(L2,0);
    digitalWrite(L3,0);
Change to:
pinMode(buttonPIN, INPUT_PULLUP);
BTW
Instead of
Use:
if (buttonState == HIGH && lastButtonState==LOW)
Instead of
int buttonPIN = 2; //Button
int L1=6; //LED 1
int L2=5; // LED 2
int L3=4; // LED 3
Use:
const byte buttonPIN = 2; //Button
const byte L1=6; //LED 1
const byte L2=5; // LED 2
const byte L3=4; // LED 3
LarryD:
Change to:
BTW
Instead of
use
I implemented the pullup resistor with an actual resistor, but I know how the INPUT_PULLUP works.
Thanks for your reply, but do you have any idea on how to declare the timeCheck function i proposed I mentioned?
This should work:
  timeCheck();
} //end loop()
void timeCheck()
  if (millis() - t1 >= timeLimit)
    digitalWrite(L1, 0);
  if (millis() - t2 >= timeLimit)
    digitalWrite(L2, 0);
  if (millis() - t3 >= timeLimit)
    digitalWrite(L3, 0);
Note:
You have set up a potential problem with the way you are using this.
The code will constantly turn off the LED when >= is met.
This might be hard find, in a much larger program, if you ever turn on L1 somewhere else.
Also, at every ~72 days >= will not be true for 2.5 seconds.
It is best to include a disable flag to preempt the above.
if (L1Flag == true && millis() - t1 >= timeLimit)
L1Flag = false;
And in:
case 1:
digitalWrite(L1,1);
t1=millis();
L1Flag = true;
LarryD:
This should work:
timeCheck();
} //end loop()
void timeCheck()
Thanks for the input. Your approach worked. Thanks!
