Declare array size in constructor function
HI.
I'm trying to create a library, containing an array. I want the user to be able to determine the size of the array when he declares the object like this:
#include <Library.h>
Library myObject(sizeOfArray)
on the library side, i've tried many solutions. the last one i did was:
Library::Library(int arraySize){
      array = new int[arraySize];
but it seems this is not the way to do it, so what should i do?
For this you need to use malloc and a pointer.
Yes, I know we say malloc() is bad, but that's not strictly true. malloc() and free() used repeatedly is bad, but a single malloc() in a constructor is fine.
class Foo {
  private:
    int *_array;
  public:
    Foo(int size) {
      _array = (int *)malloc(size * sizeof(int));
The other option is to use a static buffer. Simply pass a pointer (with the size).
Thanks for the answers. I cant test it right now, but i'll have a look
If the number is a constant ( the user value ), i.e, not generated from something like serial input / random() / analogRead(), .... ThenI would stay away from dynamic memory.
Go with the static buffer option, or use a template.
template< unsigned N >
  struct MyObjTemplate{
    int Array[ N ];
struct MyObjStatic{
  MyObjStatic( int *data, int count  ) : data( data ), count( count ) {}
  int *data;
  int count;
Template:
MyObjTemplate< 20 > obj;
Static buffer:
int data[ 20 ];
MyObjStatic obj( data, 20 );
