declare between two values
Hey! Did not find any topic about this more than using if statment.
I want to declare a middle position and that would be between 0 and 3000. How do I write this? Should I use a variable insted?
int top_position = 0;
int bottom_position = 3000;
int middle_position = ??
Could you clarify what is a middle position and how you are gong to use it?
alesam:
Between the positions 0 and 3000
int middle_position = bottom_position + (bottom_position - top_position)/2;
missdrew:
int middle_position = (bottom_position - top_position)/2;
Hm /2
Thanks!
missdrew:
That should be (bottom_position + top_position) / 2.
If you want a version that works correctly in all cases, even when overflow could occur, you have to be a bit more careful, see https://www.youtube.com/watch?v=sBtAGxBh-XI.
Pieter
maker-20_:
1, 2, 3, 4, ...., 2999 are all "between" 0 and 3000. You need to be more precise about what you want.
maker-20_:
int middle_position = top_position + random(bottom_position - top_position);
It fits your definition.
