Declaring a map??
I am writing a program and need a map in it. Here is the code:
#include "pitches.h"
int button_1 = 2;
int button_2 = 3;
int button_3 = 4;
int button_4 = 5;
int button_5 = 6;
int button_6 = 7;
int button_7 = 8;
int Button1_high = 0;
int Button2_high = 0;
int Button3_high = 0;
int Button4_high = 0;
int Button5_high = 0;
int Button6_high = 0;
int Button7_high = 0;
int Pot_pin = A0;
int Pot_value = 0;
int Speaker_pin = 13;
int Notes [][7] {
  {NOTE_C1, NOTE_D1, NOTE_E1, NOTE_F1, NOTE_G1, NOTE_A1, NOTE_B1},
  {NOTE_C2, NOTE_D2, NOTE_E2, NOTE_F2, NOTE_G2, NOTE_A2, NOTE_B2},
  {NOTE_C3, NOTE_D3, NOTE_E3, NOTE_F3, NOTE_G3, NOTE_A3, NOTE_B3},
  {NOTE_C4, NOTE_D4, NOTE_E4, NOTE_F4, NOTE_G4, NOTE_A4, NOTE_B4},
  {NOTE_C5, NOTE_D5, NOTE_E5, NOTE_F5, NOTE_G5, NOTE_A5, NOTE_B5},
  {NOTE_C6, NOTE_D6, NOTE_E6, NOTE_F6, NOTE_G6, NOTE_A6, NOTE_B6},
  {NOTE_C7, NOTE_D7, NOTE_E7, NOTE_F7, NOTE_G7, NOTE_A7, NOTE_B7},
  //Setup Pot as Input
  pinMode (Pot_pin, INPUT);
  //Setup Speaker as Output
  pinMode (Speaker_pin, OUTPUT);
  Pot_value = analogRead(Pot_pin);
  Pot_config = map(Pot_value, 0, 1023, 0, 6);
  if (Pot_value = 0) {
    Button1_high = digitalRead(button_1);
    Button2_high = digitalRead(button_2);
    Button3_high = digitalRead(button_3);
    Button4_high = digitalRead(button_4);
    Button5_high = digitalRead(button_5);
    Button6_high = digitalRead(button_6);
    Button7_high = digitalRead(button_7);
    if (Button1_high = 1) {
      //Play the tone
    if (Button2_high = 1) {
      //Play the tone
    if (Button3_high = 1) {
      //Play the tone
    if (Button4_high = 1) {
      //Play the tone
I am getting an error that the map isn't declared. I have looked everywhere and I can't see anything about declaring a map. Why is it do this?
I worked it out. I was trying to change the name of a variable that I wanted to map so it was obviously not working.
That's going to cause problems.
I believe I've already pointed this out.
I don't see why. Please enlighten me...
Because it is always going to be true ( and it makes reading the pin a waste of time)
Its an if statement...
I will have to change it to 0 though as I have noticed internal pullups are default at high.
mitchK:
Yes, I can see that.
It's also an assignment.
You probably didn't want that.
mitchK:
Assignment Operator:   =
Comparison operator:   ==
