Declaring function inside the function argument parenthesis
Hello everyone, my question is very simple but as i am not a programming expert i couldn't find the correct solution. I have this code and declaring a function and using its reference as an argument, and every class object has different functions.
class MyClass{
  public:
    uint64_t irCode;
    char btCode;
    void (*fun)(void);
    void init(uint64_t ir,char bt, void(*f)(void)){
        irCode = ir;
        btCode = bt;
        fun = f;
}myclass[2];
void f1();
void f2();
  pinMode(LED_BUILTIN, OUTPUT);
  myclass[0].init(0x000016,'a',&f1);
  myclass[1].init(0x000018,'b',&f2);
  myclass[0].fun();
  myclass[1].fun();
void f1(){
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(250);
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
  delay(250);
void f2(){
is it possible to declare function inside the init function argument like
myclass[0].init(0x000016,'a',void f1{
    delay(250);
    delay(250);
i already checked online and c++ 11 supports it but couldn't find the arduino example.
thanks
I think that what you are looking fore are lambda declarations:
pass_a_function([](void) {
  //the code for the lambda goes here
This syntax has some varieties, so search for a better understanding.
P.S: Sorry, but the new forum has a weird way of (not) formatting BB-code, so it got screwed.
You can see how this is written / done in this example (In the ESPAsyncWebServer library)
server is the instance of the AsyncWebServer class and On() is the method that takes a function pointer as argument and here a lambda is used
kernighan explains pointers to functions in The C Programming Language (pdf pg 87)
thank you all guys, lambda declaration saves me. for future visitors i am leaving the final code, though the functions do the same thing, it explains the idea.
class MyClass{
  public:
    uint64_t irCode;
    char btCode;
    void (*fun)(int);
    void init(uint64_t ir,char bt, void(*f)(int)){
        irCode = ir;
        btCode = bt;
        fun = f;
}myclass[2];
  myclass[0].init(0x000016,'a',[](int a){
      delay(a);
      delay(a);
  myclass[1].init(0x000032,'b',[](int b){
      delay(b);
      delay(b);
  myclass[0].fun(250);
  myclass[1].fun(750);
Defining a type for your function pointer would tighten up the code a little:
class MyClass{
  using FunctionPtr = void (*)(int);
  public:
    uint64_t irCode;
    char btCode;
    FunctionPtr fun;
    void init(uint64_t ir,char bt, FunctionPtr f){
        irCode = ir;
        btCode = bt;
        fun = f;
}myclass[2];
      delay(a);
      delay(a);
      delay(b);
      delay(b);
