Declaring Variables in Subroutines
In an effort to keep my code as simple and readable as possible, I tend to write using subroutines. To remain consistent I try to declare variables used only within a subroutine, inside the subroutine. Everything else is obviously declared globally in setup().
How do I declare variables inside a subroutine so they execute once, instead of every time the subroutine is called?
void setup(); { float impulse_purchase; }
void loop(); { // go to the next store
// Oops, there's something else I just MUST have!
impulse_purchase = 6.73;
money_in_pocket(); }
void money_in_pocket(void); {
void setup(); { float cash = 57.12; }
cash = cash - impulse_purchase;
return: }
In this case, cash is only used locally, so should probably be defined locally. I doubt the system would allow another setup() function inside a subroutine, but if I don't, cash is gong to be redefined as 57.12 every time the subroutine is called. (I'd try it, but I have so many other problems right now, I figured I'd be off asking the group.) This wouldn't be a problem if my variable was in fact a constant.
What do I do when it's not? Do all variables that change have to be declared globally?
I am not sure what you mean, but perhaps the static modifier is what you need.
Variable scope.
groundFungus: I am not sure what you mean, but perhaps the static modifier is what you need.
Variable scope.
This reply is proving to be surprisingly helpful. THANK YOU!!
