Decode changed in IR?
Hello! I have been facing an issue with my code, whenever i run the code i get told the following:
The function decode(&results)) is deprecated and may not work as expected! Just use decode() without a parameter and IrReceiver.decodedIRData. .
I need someone to explain what this means as i'm extremely confused as to what has changed and how to go about doing it.
The following is the code used:
#include <IRremote.h>
int IRpin = 11;
IRrecv irrecv(IRpin);
decode_results results;
irrecv.enableIRIn();
if (irrecv.decode(&results))
Serial.println(results.value, DEC);
irrecv.resume();
And if you use:
if (IrReceiver.decode())
That means that you are using code written for an older version of the IRremote library (<3.0) with the new version of the library. The GitHub page for IRremote tells how to fix older code to work with the new version.
