Decoding a message (should be simple)
I am using NRF24 to send messages from one to another Arduino.
The code looks like this
if(condition){
  unsigned long message = 10;
  RF24NetworkHeader header(node04);     // (Address where the data is going)
  bool ok = network.write(header, &message, sizeof(message)); // Send the data
On the receiver side it looks like this:
network.update();
   while ( network.available() ) {     // Is there any incoming data?
   RF24NetworkHeader header;
   unsigned long message;
   network.read(header, &message, sizeof(message)); // Read the incoming data
   if (message == 10){
   do something;
If I want to do something at a receiving site, I need to write an if statement and specifically tell Arduino what to do.
What I would like is a code that would tell receiving site, what to do.
Example.
I want to turn on RGB led and buzzer.
r = 255
g = 050
b = 0
buzzer = 1
I would like to send a code 2550500001 and the receiving arduino would decode it.
I know how to make the code. Message = r10000000 + g100000 + etc...
Question: Is there some way to decode this message?
Thank you
Send a struct containing the values to be used by the receiver. That way you send a single message that is easily decoded and used. Alternatively add delimiters between the data items that you send and parse it in the receiver code using the delimiters
Personally I would favour using a struct because it allows you to use meaningful variable names within it
Examples
Sending a struct
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
//not all #defines used but here for documentation
#define CE_PIN   9
#define CSN_PIN 10
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
const byte slaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char txNum = '0';
struct data
  byte pinState;
  byte temperature;
} sentData;
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000;
  Serial.println("SimpleTx Starting");
  radio.begin();
  radio.setDataRate( RF24_250KBPS );
  radio.setRetries(3, 5); // delay, count
  radio.openWritingPipe(slaveAddress);
  currentMillis = millis();
  if (currentMillis - prevMillis >= txIntervalMillis)
    sentData.pinState = !sentData.pinState;
    sentData.temperature = sentData.temperature + 1;
    send();
    prevMillis = millis();
void send()
  bool rslt;
  rslt = radio.write( &sentData, sizeof(sentData) );
  if (rslt)
    Serial.println("  Acknowledge received");
    Serial.println("  Tx failed");
Receiving a struct
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
const byte thisSlaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
struct data
  byte pinState;
  int temperature;
} receivedData;
bool newData = false;
  Serial.println("SimpleRx Starting");
  radio.begin();
  radio.openReadingPipe(1, thisSlaveAddress);
  radio.startListening();
  getData();
  showData();
void getData()
  if ( radio.available() )
    radio.read( &receivedData, sizeof(receivedData) );
    newData = true;
void showData()
  if (newData == true)
    Serial.print("Data received\tpinState : ");
    Serial.print(receivedData.pinState);
    Serial.print("\t");
    Serial.print("temperature : ");
    Serial.println(receivedData.temperature);
    newData = false;
you could use sscanf() to parse your code "2550500001" , e.g.
  char data[]="2550500001";
  int r,g,b,buzzer;
  if(sscanf(data,"%3d%3d%3d%1d",&r,&g,&b,&buzzer)==4) {
    Serial.println(r);
    Serial.println(g);
    Serial.println(b);
    Serial.println(buzzer);
  Serial.println("invalid data");
void loop() {}
a run gives
09:30:30.128 -> 255
09:30:30.128 -> 50
09:30:30.128 -> 0
09:30:30.128 -> 1
alternativly you could send a code such as "R255G50B0BUZZER1" and use sscanf() to parse it, e.g.
  if(sscanf(data,"R%dG%dB%dBUZZER%d",&r,&g,&b,&buzzer)==4) {
I'll bet that works. But, as has been discussed here many times (strict C++ typing, undefined behavior, etc), that should probably be replaced with a read() into a uint8_t buffer followed by a memcpy() into receivedData.
EDIT:
Sorry, my bad. The read function uses memcpy().
Thank you,
this is exactly what I was looking for, googling and searching like crazy, and nothing :smiley:
The closest I got was this, but I did not know how the % and other symbols work, so Thank you.
int thousands, hundreds, tens, ones;
int x = 9431;
thousands = (x % 10000) / 1000;
hundreds = (x % 1000) / 100;
tens = (x % 100) / 10;
ones = (x % 10);
Note that when % is used in sscanf() it means something completely different to when it is used in an expression such as ones = (x % 10);
Thank you, was just reading many threads about sscanf(), I am pretty used to parsing with https://regex101.com/ so this looks a bit similar, so I think I will get it to work. Thanks
