Hello, Thanks for your interest and offer to help.
Hopefully I've included the correct bits that you asked for.
The different sketch is from my rain alarm I am making.
// Include RadioHead Amplitude Shift Keying Library
#include <RH_ASK.h>
// Include dependant SPI Library
#include <SPI.h>
int J; // number of loops it waits if no signal before sounding alarm.
int buzzPin = (7); // buzz pin
int buzzOn =(3000);
int buzzOff =(2000);
int RedOff =(1000);
int redPin = (4);
int greenPin = (5);
int yellowPin = (2);
int delayTime = (500); // time programe waits before moving on.
int noSignal = (1000);
int M; // count for length of buzz if moist
int MoistBuzzTime =(12000);
// D11--------------------------Data
// Create Amplitude Shift Keying Object
RH_ASK driver (256, 11, 12);
// Setup Serial Monitor
if (!driver.init()) Serial.println("init failed");
pinMode ( buzzPin, OUTPUT);
pinMode ( redPin, OUTPUT);
pinMode ( greenPin, OUTPUT);
pinMode ( yellowPin, OUTPUT);
digitalWrite(greenPin,HIGH);
// Set buffer to size of expected message
uint8_t buf[1];
uint8_t buflen = sizeof(buf);
uint8_t i;
// Check if received packet is correct size
if (driver.recv(buf, &buflen))
// Message received with valid checksum
// Serial.print("Message Received: ");
// Serial.println((char*)buf);
J = -1;
else { J = ( J + 1);}
if (J > 21) { goto End;}
if (J == 21){
// Serial.println ("No Signal");
digitalWrite(buzzPin,HIGH); // continuous buzz for signal lost.
digitalWrite(greenPin,LOW);
digitalWrite(redPin,HIGH);
digitalWrite(yellowPin,LOW);
// delay ( noSignal);
goto End;}
else {
if (J < 21)
// Serial.println("ON");
String rcv;
for (int i = 0; i < buflen; i++) {
rcv += (char)buf[i];
Serial.println( rcv);
{ if (rcv=="D")
{ digitalWrite(buzzPin,LOW);
digitalWrite(redPin,LOW); // buzzer off as it is dry.
(M = 1) ;}
if (rcv=="W") // buzzer for wet
{ digitalWrite(redPin,HIGH);
//delay(buzzOn);
//digitalWrite(buzzPin,LOW);
(M = 1) ;
//digitalWrite(redPin,LOW);
//delay(RedOff);
//Serial.println( " Wet Buzz");
if (rcv=="M")
// M = (M+1);
if (M == 1){ (M = 2) ;
digitalWrite(yellowPin,HIGH);}
digitalWrite(redPin,LOW); // Turn it off just in case it is on.
delay (MoistBuzzTime); // Moist buzz time to be decided
//delay(250);
//Serial.println( " Moist Buzz");
End:
Serial.println( J);
delay (delayTime);
The output shown "D" it is dry. The numbers are a count before a no signal alarm is raised. If the signal drops and and it rains the washing will still get wet.
"Even if the remote uses some version of the RCSwitch protocol, it may be one of the several variants that the default library example does not recognize. "
This had occurred to me which is why I used the "RecieveDemo Simple" ( The Sketch in my original post) when the "RecieveDemo Advanced" did not give a readout. My understanding of the "Simple" Sketch is that it will give an indication that it has received something even if it does not decode it.?
Thanks John
