`Hi so im trying to decode another IR sensor. This is connected with a 1.5 ton unit card. The chip im using is ESP32 devkitV1. Not getting the required protocol. What seems to be the issue?
#include <Arduino.h>
#include <IRrecv.h>
#include <IRremoteESP8266.h>
#include <IRac.h>
#include <IRtext.h>
#include <IRutils.h>
const uint16_t kRecvPin = 14;
const uint32_t kBaudRate = 115200;
const uint16_t kCaptureBufferSize = 1024;
#if DECODE_AC
const uint8_t kTimeout = 50;
#else // DECODE_AC
// Suits most messages, while not swallowing many repeats.
const uint8_t kTimeout = 15;
#endif // DECODE_AC
const uint16_t kMinUnknownSize = 12;
// Legacy (No longer supported!)
// Change to `true` if you miss/need the old "Raw Timing[]" display.
#define LEGACY_TIMING_INFO false
// ==================== end of TUNEABLE PARAMETERS ====================
// Use turn on the save buffer feature for more complete capture coverage.
IRrecv irrecv(kRecvPin, kCaptureBufferSize, kTimeout, true);
decode_results results; // Somewhere to store the results
// This section of code runs only once at start-up.
#if defined(ESP8266)
Serial.begin(kBaudRate, SERIAL_8N1, SERIAL_TX_ONLY);
#else // ESP8266
Serial.begin(kBaudRate, SERIAL_8N1);
#endif // ESP8266
while (!Serial) // Wait for the serial connection to be establised.
delay(50);
Serial.printf("\n" D_STR_IRRECVDUMP_STARTUP "\n", kRecvPin);
#if DECODE_HASH
// Ignore messages with less than minimum on or off pulses.
irrecv.setUnknownThreshold(kMinUnknownSize);
#endif // DECODE_HASH
irrecv.enableIRIn(); // Start the receiver
// The repeating section of the code
// Check if the IR code has been received.
if (irrecv.decode(&results)) {
// Display a crude timestamp.
uint32_t now = millis();
Serial.printf(D_STR_TIMESTAMP " : %06u.%03u\n", now / 1000, now % 1000);
// Check if we got an IR message that was to big for our capture buffer.
if (results.overflow)
Serial.printf(D_WARN_BUFFERFULL "\n", kCaptureBufferSize);
// Display the library version the message was captured with.
Serial.println(D_STR_LIBRARY " : v" _IRREMOTEESP8266_VERSION_ "\n");
// Display the basic output of what we found.
Serial.print(resultToHumanReadableBasic(&results));
// Display any extra A/C info if we have it.
String description = IRAcUtils::resultAcToString(&results);
if (description.length()) Serial.println(D_STR_MESGDESC ": " + description);
yield(); // Feed the WDT as the text output can take a while to print.
#if LEGACY_TIMING_INFO
// Output legacy RAW timing info of the result.
Serial.println(resultToTimingInfo(&results));
yield(); // Feed the WDT (again)
#endif // LEGACY_TIMING_INFO
// Output the results as source code
Serial.println(resultToSourceCode(&results));
Serial.println(); // Blank line between entries
```IRrecvDump is now running and waiting for IR input on Pin 14
Timestamp : 000010.420
Library : v2.8.4
Protocol : UNKNOWN
Code : 0xA2A143C6 (26 Bits)
uint16_t rawData[51] = {9616, 3966, 874, 452, 852, 476, 850, 1492, 820, 506, 852, 454, 874, 450, 820, 1574, 852, 1492, 874, 1492, 852, 454, 872, 450, 820, 506, 852, 1494, 872, 454, 850, 1496, 872, 1492, 850, 1518, 878, 424, 848, 1520, 850, 452, 874, 1492, 850, 476, 852, 1492, 818, 508, 850}; // UNKNOWN A2A143C6
Timestamp : 000017.073
Library : v2.8.4
Protocol : UNKNOWN
Code : 0x9D936F9A (26 Bits)
uint16_t rawData[51] = {9614, 3966, 846, 504, 852, 1494, 874, 1492, 850, 476, 852, 452, 846, 478, 852, 1494, 874, 1492, 850, 1496, 872, 450, 820, 506, 852, 454, 874, 1490, 850, 1518, 850, 450, 846, 1520, 852, 1492, 874, 452, 850, 1494, 874, 450, 820, 1548, 850, 452, 874, 1494, 850, 454, 874}; // UNKNOWN 9D936F9A``
