Decoupling capacitors for a multiplexer chip
I've got myself a 74HC157 multiplexer chip for my project, this is being used to switch between pwm signal coming out of an Arduino and pwm signal coming out of a radio control plane receiver, the signal eventually goes to some servos.
Here's the data sheet for anyone interested
http://www.nxp.com/documents/data_sheet/74HC_HCT157.pdf
My question is what size of decoupling capacitor should I be putting on the VCC of this chip, most people I have asked have said choosing decoupling caps is more of an art than a science but I'm not exactly well practised in this :(.
Could someone recommend a good size for this or possibly a good guide on how to choose caps for when I need to do the same thing in future, and also are there any other obvious components I should require before adding this to my circuit?
Thanks in advance
0.1uF ceramic cap on each VCC/AVCC pin of every device.
For example, on this board there are 13 ICs, and 16 decoupling caps - the '328P has 3, on VCC - AVCC - Aref.
50V rated parts are fine and usually very inexpensive:
http://www.dipmicro.com/store/C5K10-50
Buy a bag of 100, 200, be set for quite a few projects.
Wow thank you! that's perfect will go grab some now.
