Decrementing a value using tft button
I'm using Arduino Mega and 3.5" TFT Display.
I want to increment and decrement a value by 10, using on-screen buttons.
But it misbehaves after reaching 100. Does somebody know why? I think the problem is in the decrement formula.
Code:
int volt = 0;
int diff = 10;
void loop(){
if (sub_btn.justPressed()) {
sub_btn.drawButton(true);
volt = volt - diff;
if (add_btn.justPressed()) {
add_btn.drawButton(true);
volt = volt + diff;
I've been misbehaving all my life and I am no where near 100!!!
Please explain what 'misbehaving' means.
HAHA..
It increments from 0 to 255.
It decrements also properly upto 100.
But after further decrementing from 100 it becomes 900.
White decrementing for example: 130, 120, 110, 100, 900, 800, 700, 600, 500, 400, 300, 200, 100, 000
The code you posted is obviously not complete. Please post complete code and please remember to format it correctly and use code tags </> as per the forum instructions.
Thanks
This is the entire code.
#include "MCUFRIEND_kbv.h"
#include "TouchScreen.h"
#include <Adafruit_GFX.h>
MCUFRIEND_kbv tft;
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define MINPRESSURE 200
#define MAXPRESSURE 1000
const int XP = 8, XM = A2, YP = A3, YM = 9;
const int TS_LEFT = 128, TS_RT = 908, TS_TOP = 950, TS_BOT = 100;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
TSPoint tp;
Adafruit_GFX_Button sub_btn, add_btn;
int pixel_x, pixel_y;
bool Touch_getXY()
  TSPoint p = ts.getPoint();
  pinMode(YP, OUTPUT);
  pinMode(XM, OUTPUT);
  digitalWrite(YP, HIGH);
  digitalWrite(XM, HIGH);
  bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
  if (pressed) {
    pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width());
    pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
  return pressed;
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
int motor = 45;
int volt = 0;
int diff = 10;
  uint16_t ID = tft.readID();
  tft.reset();
  tft.begin(0x9486);
  tft.setRotation(0);
  tft.setCursor(20, 10);
  tft.setTextColor(WHITE);
  tft.setTextSize(2);
  tft.print("PRECISION PRODUCTS");
  tft.setCursor(100, 40);
  tft.setTextSize(2);
  tft.print("PVT. LTD.");
  tft.setCursor(100, 80);
  tft.setTextColor(WHITE, RED);
  tft.setTextSize(3);
  tft.print("Oxygen");
  tft.setCursor(50, 120);
  tft.setTextSize(3);
  tft.print("Concentrator");
  sub_btn.initButton(&tft,  60, 250, 100, 40, WHITE, CYAN, BLACK, "-", 3);
  add_btn.initButton(&tft, 252, 250, 100, 40, WHITE, CYAN, BLACK, "+", 3);
  sub_btn.drawButton(false);
  add_btn.drawButton(false);
  pinMode(motor, OUTPUT);
  bool down = Touch_getXY();
  sub_btn.press(down && sub_btn.contains(pixel_x, pixel_y));
  add_btn.press(down && add_btn.contains(pixel_x, pixel_y));
  if (sub_btn.justReleased())
    sub_btn.drawButton();
  if (add_btn.justReleased())
    add_btn.drawButton();
    volt = volt - diff;
    volt = volt + diff;
  tft.setCursor(120, 235);
  tft.setTextColor(TFT_RED, TFT_BLACK);
  tft.setTextSize(4);
  tft.print(volt);
int pressureValue = analogRead(46);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float pressure = pressureValue * (5.0 / 1023.0);
tft.setCursor(100, 400);
tft.setTextSize(4);
tft.print(pressure);
analogWrite(motor, volt);
OK, thanks.
I don't have the right experience to help, sorry, maybe someone else can.
bonyl:
If you do not want it it increment above 100 add an “if” statement…
if (volt < 100) volt = volt + diff;
…also similarly for decreasing.
It’s displaying 90 correctly. The extra “0” on the end is what was left over from displaying “100”.
Add…
tft.print(" ");
…to overwrite the last digit.
Posted in error...
It worked. Thanks for explaining.
Really appreciate it.
