Hi All
I had this code working perfectly yesterday on a ESP32 dev board and battery out in the yard. For what ever reason it disconnected, possibly a flat battery. Now it can get the unit into deep sleep mode.
I haven't changed anything hardware or software wise.
I have charged the battery and the readings are there but it won't sleep now. I have reloaded the code and tried the second code which puts it into deep sleep.
Any ideas?
Cheers
[code]
#include <HX711.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <DHT.h>
#define calibration_factor -21500.0
#define zero_factor 8364129
#define LOADCELL_DOUT_PIN 22
#define LOADCELL_SCK_PIN 23
#include <WiFi.h>
#include <HTTPClient.h>
// Replace with your network credentials
const char* ssid = "";
const char* password = "";
// REPLACE with your Domain name and URL path or IP address with path
const char* serverName = "";
// Keep this API Key value to be compatible with the PHP code provided in the project page.
// If you change the apiKeyValue value, the PHP file /post-data.php also needs to have the same key
String apiKeyValue = "";
#define DHTPIN 4 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
#define ONE_WIRE_BUS 15 // Data wire is connected to GPIO15
HX711 scale;
// Setup a oneWire instance to communicate with a OneWire device
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
DeviceAddress sensor1 = { 0x28, 0x6A, 0x48, 0x7C, 0x0C, 0x00, 0x00, 0xC4 }; // long
DeviceAddress sensor2 = { 0x28, 0xFA, 0x14, 0x7B, 0x0C, 0x00, 0x00, 0x47 }; //short
DHT dht(DHTPIN, DHTTYPE);
// Time to sleep
uint64_t uS_TO_S_FACTOR = 1000000; // Conversion factor for micro seconds to seconds
// sleep for 30 minutes = 1800 seconds
uint64_t TIME_TO_SLEEP = 1800;
// Get Sensor Readings
String getSensorReadings(){
sensors.requestTemperatures();
sensors.begin();
dht.begin();
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.set_offset(zero_factor); //Zero out the scale using a previously known zero_factor
WiFi.begin(ssid, password);
Serial.println("Connecting");
while(WiFi.status() != WL_CONNECTED) {
Serial.print(".");
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
#ifdef ESP32
// enable timer deep sleep
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
Serial.println("Going to sleep now");
// start deep sleep for 3600 seconds (60 minutes)
#else
// Deep sleep mode for 3600 seconds (60 minutes)
// Serial.println("Going to sleep now");
ESP.deepSleep(TIME_TO_SLEEP * uS_TO_S_FACTOR);
#endif
void loop(){
//Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
HTTPClient http;
// Your Domain name with URL path or IP address with path
http.begin(serverName);
// Specify content-type header
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
// Prepare your HTTP POST request data
String httpRequestData = "api_key=" + apiKeyValue + "&value1=" + String(dht.readTemperature())
+ "&value2=" + String(dht.readHumidity()) + "&value3=" + String(sensors.getTempC(sensor1)) + "&value4=" + String(sensors.getTempC(sensor2))+ "&value5=" + String(scale.get_units(), 1) +"";
Serial.print("httpRequestData: ");
Serial.println(httpRequestData);
// Send HTTP POST request
int httpResponseCode = http.POST(httpRequestData);
// If you need an HTTP request with a content type: text/plain
//http.addHeader("Content-Type", "text/plain");
//int httpResponseCode = http.POST("Hello, World!");
// If you need an HTTP request with a content type: application/json, use the following:
//http.addHeader("Content-Type", "application/json");
//int httpResponseCode = http.POST("{\"value1\":\"19\",\"value2\":\"67\",\"value3\":\"78\"}");
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
else {
Serial.print("Error code: ");
// Free resources
http.end();
else {
Serial.println("WiFi Disconnected");
// //Send an HTTP POST request every 30 seconds
// delay(30000);
// // Wait a few seconds between measurements.
// delay(20000);
//Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
// Serial.println("DONE");
Serial.print("8 Frame Hive: ");
Serial.print(sensors.getTempC(sensor1));
Serial.print("°C: ");
Serial.print("10 Frame Hive: ");
Serial.print(sensors.getTempC(sensor2));
Serial.print("Weight ");
Serial.print(scale.get_units(), 1);
Serial.print(" Kgs ");
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
Serial.print(F("8 Frame Roof Temp: "));
Serial.print(t);
Serial.print(F("°C "));
Serial.print(F("8 Frame Roof Humidity: "));
Serial.print(h);
Serial.print(F("% "));
Serial. print('\n');
// start deep sleep for 1800 seconds (30 minutes)
esp_deep_sleep_start();
[/code]
[code]
#include <Arduino.h>
#define uS_TO_S_FACTOR 1000000 /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP 10 /* Time ESP32 will go to sleep (in seconds) */
void setup(){
Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) + " Seconds");
Serial.flush();
Serial.println("This message will never be printed");
void loop(){
[/code]
