DeepSleep current issue on ESP8266
Setup:
YouTube: Setup Video
  • ESP8266 connected with LDO MCP1700-33 to a 18650.
  • Measuring current through multimeter.
  • Sketch as below, blink few times then go to deepsleep for some seconds.
Issue:
Current on multimeter shows over 8mA in deep sleep mode which should be around 20μa.
Troubleshooting performed:
  • Added delay(100) at end of sketch, same result
Maybe someone could shed some light on whats going on. Highly appreciated!
  pinMode(LED_BUILTIN, OUTPUT);     // Initialize the LED_BUILTIN pin as an output
// the loop function runs over and over again forever
  for (int i = 0; i <= 5; i++) {
      digitalWrite(LED_BUILTIN, LOW);   // Turn the LED on (Note that LOW is the voltage level
      // but actually the LED is on; this is because
      // it is active low on the ESP-01)
      delay(1000);                      // Wait for a second
      digitalWrite(LED_BUILTIN, HIGH);  // Turn the LED off by making the voltage HIGH
      delay(1000);                      // Wait for two seconds (to demonstrate the active low LED)
  ESP.deepSleep(10e6);
Solved, remove 0ohm resistor to make LDO work!
