Default compiler in Arduino
I do not know C++. ..... For low level programming I use assembler and C.
1. How to change default compiler for Arduino to avr-gcc ????
So far I could not get any of my C code compiled in Arduino, however I can build them from terminal command line i.e. not using Arduino at all.
2. Can I use program.elf ( or a.out) to load ( program flash ) to the board ? or has to be program.hex ?
3. Can I import program.elf or program.hex to Arduino just for burning flash ?
The "robot" computer I try to use is Plololu Orangutan SV 328
Machine I use is:
Linux localhost 3.10.7-gentoo #2 SMP PREEMPT Fri Mar 7 07:06:21 UTC 2014 x86_64 AMD FX(tm)-8150 Eight-Core Processor AuthenticAMD GNU/Linux
Thanks for your time .....
What compiler does it use as a default at present I wonder.
This SHOULD work. What kinds of problem are you having?
UKHeliBob:
From Arduino console:
avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections ..... ....
westfw:
So far syntax is not recognized by avr-g++ , I use ISO standard C.
Having issues with lib path so this has to be dealt first. Do nut rush in to details yet .. I am just testing my setup before getting to serious work.
Can you post a simple example of some code that you are having problems with and details of where you have your libraries installed ?
