Greetings,
I am just beginning to play with the Dallas Semiconductor DS18S20 and the OneWire library and out of the gate seeing some strange results.
I am using the default temperature sensor example. I'm connecting a single DS18S10 to pin 10 of my Leonardo with a 4.7K pullup resistor, not using parasitic power. The sketch compiles, uploads, and runs just fine from either Arduino 1.0.5 or 1.5.7 on my Mac with OS X Mavericks. It seems to see the DS18S20 and extract its serial number, which seems to pass the CRC check. But the temperatures are well into the negative territory. They do respond to temperature changes, so it's clear that data is being read, but not interpreted correctly.
At first blush I'd guess there is a byte order problem or byte misalignment or something of that type, but without a proper debugger I'm just stabbing in the dark. Is there something peculiar about Arduino on the Mac that perhaps was missed when the library was made? My best Googling skills are not helping.
Here's the output from a few runs with the sensor between my fingers to raise the temperature.
ROM = 10 3D AE 62 0 8 0 2C
Chip = DS18S20
Data = 1 BE FF 0 0 FF FF C 10 38 CRC=38
Temperature = -33.00 Celsius, -27.40 Fahrenheit
No more addresses.
Chip = DS18S20
Data = 1 C0 FF 0 0 FF FF F 10 61 CRC=61
Temperature = -32.19 Celsius, -25.94 Fahrenheit
No more addresses.
Chip = DS18S20
Data = 1 C1 FF 0 0 FF FF 1 10 FE CRC=FE
Temperature = -31.31 Celsius, -24.36 Fahrenheit
No more addresses.
Chip = DS18S20
Data = 1 C3 FF 0 0 FF FF 7 10 D2 CRC=D2
Temperature = -30.69 Celsius, -23.24 Fahrenheit
No more addresses.
Chip = DS18S20
Data = 1 C4 FF 0 0 FF FF F 10 74 CRC=74
Temperature = -30.19 Celsius, -22.34 Fahrenheit
No more addresses.
Chip = DS18S20
Data = 1 C4 FF 0 0 FF FF A 10 8B CRC=8B
Temperature = -29.87 Celsius, -21.77 Fahrenheit
No more addresses.
The example code:
#include <OneWire.h>
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
OneWire ds(10); // on pin 10 (a 4.7K resistor is necessary)
void setup(void) {
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
