"DEFAULT ELSE"
The documentation for the "if..else" control structure (else - Arduino Reference) makes reference to the "default else." I don't understand how to tell which else is the default. Or how to tell if one is present or not.
It's just telling you that you can use else to create a default action if none of the else if statements are true.
Just odd phrasing. I think they're intending to analogize to the switch/case statement's "default" keyword? (I recommend not using switch case - it is much easier to write bugs with switch/case). Sometimes thinking of it as a default makes a lot of sense, other times very little.
They mean that if you have an if/else if chain, if it ends with an else, that's the "default" action that is carried out if none of the conditions are true, eg:
if (x==1) {
   doStuff();
} else if (x==2) {
   doOtherStuff();
} else {  //executed if x is neither 1 nor 2, eg, what they term the "default" behavior.
   doDefaultAction();
if (x==1) {
   doStuff();
} else if (x==2) {
   doOtherStuff();
} //if we don't need that "default" action, we don't end it with an else.
rossed:
I don’t understand how to tell which else is the default.
If you have a series of IF ELSE clauses a final ELSE will deal with everything that the others missed.
It will only be there if you put it there.
There is no requirement to have a default ELSE and there are situations where it is not desirable.
…R
