Hi guys,
does arduino support a indexed default class?
something like:
class pins
private:
pin all_pins[MAX_PINS];
public:
pin default(int);
thanks in advanced
Hi guys,
something like:
class pins
private:
public:
pin default(int);
thanks in advanced
What is pin? all_pins looks like an array, while default looks like a function.
I'm confused by the question.
pin is another class and all_pins in pins class is an array of pins class
the point is to do something like:
class pins
private:
public:
pin default(int);
pin pins::default ( int index )
return all_pins[index];
to declare all pins:
pins allpins;
to use it:
allpins[1].<pin_class_properties> …
No, it isn’t. It’s an array of pin (no s) objects.
pins allpins;
allpins is an instance of the pins class. It is not an array of anything, so:
is wrong.
If you create an instance of the pins class:
pins myPins;
then, myPins has a member, all_pins, that is an array of pin objects, so you could do this:
myPins.all_pins[14].somePinClassMethod();
Where does the default() method come into play? What does the pins constructor look like? In the example, you haven’t declared one.
well, thanks a lot for your reply. I know [u]some[/u] C and C++ but I don't program for a while now. I understand what you said, and I know I can call it like that. actually I don't, because all_pins is private, but it really doesn't matter, because that was not my question. I just wanted to know if I can use the default feature of the class.
I know I can use: myPins.all_pins[14].somePinClassMethod();
but wouldnt it be easyer to use: myPins[14].somePinClassMethod();
Anyway, nevermind. I'll do it the hard way and move the all_pins to public.
thanks
That is certanly possible! Operator overloading is what it’s called.
I’m too busy to show you, but google it and you’ll find the answer.
I know I can use:
myPins.all_pins[14].somePinClassMethod();but wouldnt it be easyer to use:
How could you? myPins would need to be an array of instances of the pins (plural) class, rather than a member that was an array of instances of the pin (singular) class. They are not even close to being the same thing.
class pins {
public:
pin& operator[] (unsigned i) {return all_pins[i]; }
pins myPins;
I think that that's really stretching the [] operator. Typically, I expect the [] operator to return an object of the same type as it is called from.
But, it is an interesting concept.
When indexing a class called 'pins' I do not find it strange to receive a pin?
If I have int stuff[20]; with values in each position, I expect [] to return an int.
I expect that if I have an array of pins objects, for [] to return a pins. If I have an array of pin objects, I expect [] to return a pin object.
I do not expect pins::[] to return a pin object.
But, that could just be me.
PS. I hate DELL laptop keyboards.
I cant help myself but to answer this :)
I won't bother to put this in code tags but:
int my_pins[10];
clearly indicate a collection of ints. And as such, should return an int when accessed by the index operator.
int pin2 = my_pins[1]; //looks like it works
Now, lets keep this in mind, accessing a collection returns an instance from that collection.
pins my_pins; //what's this? my_pins is not an array, but an object? curious...
pin pin2 = my_pins[1]; //works as well
The ontology is valid. The pins collection still return a pin, what's changed is the type of a pin.
This problem we're discussing now has been discussed up and down by c++ communities. Does operator overloading ever provide an API with unambiguous meaning?
class Array { /implement/ } might be the definite argument for 'yes' but is it better than a get(i) or at(i) even item(i) ?
I like operator overloading, but it should be used with care.
