Defective Ethernet Shield?
I think my Ethernet Shield may be defective, and I'm wondering how best to diagnose the possible damage?
I know that my Mega board is working, I've had success with a few sketches reading from temperature sensors and controlling LEDs.
I've tried uploading a few sketches from tutorials I've found, but nothing seems to work, attempts usually end in the following error:
I thought I was getting nothing when I uploaded the code and connected the ethernet cable, and was about ready to give up, but I tried the generic 'webserver' example again (File->Examples->Ethernet->Webserver) with just the board, detached from the shield, reattached the shield after uploading, and I found that (even though I didn't see it listed on the DHCP clients table through my router) I am getting some feedback from it when I give my browser its location:
analog input 0 is 570
analog input 1 is 533
analog input 2 is 445
analog input 3 is 426
analog input 4 is 427
analog input 5 is 392
Is it defective? It doesn't allow me to upload code while the shield is in place, but code works if I wait to attach the shield until after code is uploaded. Is there anything I can do to fix it without trying to solder anything?
Which Ethernet shield? Link?
arduino's own:
Yoi are vague about the code you have been using, but the result of the last code you tried indicates the board is operating correctly. Below is a version of the code that you apparently tried that refreshes in the browser that you can try.
// zoomkat meta refresh server test code
// arduino IDE 1.0
// for W5100 ethernet shield
// the IP address will be dependent on your local network/router
// port 80 is default for HTTP, but can be changed as needed
// use IP address like http://192.168.1.102:84 in your brouser
// or http://zoomkat.no-ip.com:84 with dynamic IP service
// use the \ slash to escape the " in the html
// meta refresh set for 2 seconds
#include <SPI.h>
#include <Ethernet.h>
int x=0; //set refresh counter to 0
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,102); // ip in lan
EthernetServer server(84); //server is using port 84
  // start the server
  Ethernet.begin(mac, ip);
  server.begin();
  // listen for incoming clients
  if (client) {
     while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // see if HTTP request has ended with blank line
        if (c == '\n') {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println();
          //meta-refresh page every 2 seconds
          x=x+1; //page upload counter
          client.println("<HTML>");
          client.print("<HEAD>");
          client.print("<meta http-equiv=\"refresh\" content=\"2\">");
          client.print("<TITLE />Zoomkat's meta-refresh test</title>");
          client.print("</head>");
          client.println("<BODY>");
          client.print("Zoomkat's meta-refresh test IDE 1.0");
          client.println("
          client.print("page refresh number ");
          client.println(x); //current refresh count
          client.println("
          client.println("
          client.print("Zoomkat's arduino analog input values:");
          client.println("
          client.println("
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(analogRead(analogChannel));
            client.println("
          client.println("</BODY>");
          client.println("</HTML>");
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
yeah, that looks like the code I most recently tried (and had the most success with).
But shouldn't I be able to upload sketches while the shield is on (connected) to the main board?
Kent88:
Should yes. If you bought an official shield and use an official Arduino.
The clones from places like eBay are generally the ones with the upload issue.
You can try bending pins 0 and 1 from the shield, to prevent them from going into the sockets of pins 0 and 1 on your Arduino. The shield doesn't need them.
Kent88:
If you bought an ethernet shield that is "PoE" ready, them you may need to reset the board manually at the start of code upload.
Good morning
I have a similar problem. When I use Ubuntu 12.04 to upload File->Examples->Ethernet->Webserver on Arduino 0022, the firefox never shows anything. But, when I am using Windows 7 or Ubuntu 11.04 to upload File->Examples->Ethernet->Webserver on Arduino 0022 IDE, the firefox shows the right things.
I do not know what I have to do on Ubuntu 12.04?
Any help is going to be wellcome.
Attentively
Wilber.
I recommend upgrading to IDE v1.0.1. Prior versions had a bug in the ethernet library. The formats are different on some function calls tho.
