I need the definition of following function sendATcommand(), i have searched for it but didnt get it .
What library is the function comtained in?
Perhaps you should post the program that uses the function.
...R
i don't know which is the library . I tried to found but did't find any thing . I have attached the code also giving the link of resource . Its for GSM 3g shield
dfsd.txt (3.71 KB)
The function is implemented starting on line 115 of your file.
nope..in txt file ..47 ,52 ,53 number line
Fazlay:
What is that supposed to mean?
I can also see it at Line 115
...R
Robin2:
Fazlay:
nope..in txt file ..47 ,52 ,53 number lineWhat is that supposed to mean?
It is called on those lines, also on lines 55, 99 and 109.
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
Is this not the sendATcommand you're looking for?
yes this is ....
@Fazlay, is it documentation that you are looking for? It's probably with the library distribution that you downloaded. Sometimes it is kept on the website where the library came from.
