(Is it correct?)
Of course not. This discussion has been had MANY, MANY times, so use the forum search function.
(Is it correct?)
jremington:
the engineer in me says using one over the other is trivially negligible anyways.
1 ÷ 1023 = 0.0009775171
1 ÷ 1024 = 0.0009765625
difference = 0.0000009546
the difference is detected at two/three orders of magnitude lower...
but the 1024 is correct...
Student took a test and got 67 out of 100 questions correct... Student scored 67%, not 68% (67 ÷ 99).
all of this is off topic, so my apologies to OP
That means:
When Vin is equal to Vref, the ADC value is 11-bit (100 0000 0000 = 1024); whereas, the ADC, in question, has 10-bit resolution!
But the definition says:
Full Scale is the value when all the bits of the ADC assume LH states in response to the input value that is equal to Vref.
GolamMostafa:
That means:
When Vin is equal to Vref, the ADC value is 11-bit (100 0000 0000 = 1024); whereas, the ADC, in question, has 10-bit resolution!But the definition says:
you are correct! max value is 1023 not 1024... I stand corrected!
Thanks!!
and +1.
robtillaart:
This is typical one of the problems of #define that const solvestry
const float R1 = 984000;
const float R2 = 472000;no decimal point needed and the compiler gets the type information it needs.
I have understand that const would be better than #define in this case. But the open source project that i am using (and trying to improve) all uses #define for all values that the end user are supposed to adjust to there specific hardware setup . I would like to follow that style.
strixx:
so look at reply 11 using the constexpr function:
#define R1 984000
#define R2 472000
constexpr float batFact(float a, float b)
return ((1.1/1023)*((a+b)/b));
const float myValue = batFact(R1, R2);
Serial.println(myValue, 8);
BulldogLowell:
so look at reply 11 using the constexpr function:#define R1 984000
#define R2 472000
What would be the difference between this solution and the ones suggested in #4 and #6
#define R1 984000
#define R2 472000
const float batFact = ((1.1/1023)*(((float)R1+R2)/R2));
strixx:
What would be the difference between this solution and the ones suggested in #4 and #6#define R1 984000
#define R2 472000
just a few:
OK. I understand.
Thank you very much and everybody for all the help and explanations.
Going to bed tonight a little bit wiser... ![]()
