#define debug true
Hey I really need your help guys. I'm trying to learn this code. Here is my first question of many questions.
What does... #define debug true.. do?
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, NEGATIVE);
#define I2C_ADDR 0x27  // Define the address of the serial communication display
#define LED_OFF 0
#define LED_ON 1
#define debug true
int ledPin = 13;          //The pin, your LED is connected to.
int speakerPin = 9;       //The pin, your buzzer or speaker is connected to.
int pitch1 = 140;
int pitch2 = 140;
int dot = 50;
int dash = 3 * dot;
String morseATable[] = { ".-", "-...", "-.-.", "-..", ".", "..-.", "--.",   // A-G
                         "....", "..", ".---", "_._", ".-..", "--", "-.",    // H-N
                         "---", ".--.", "--.-", ".-.", "...", "-", "..-",    // O-U
                         "...-", ".--", "-..-", "-.--", "--.."               // V-Z
String morseNTable[] = { "-----", ".----", "..---", "...--", "....-",       // 0-4
                         ".....", "-....", "--...", "---..", "----."         // 5-9
  lcd.begin(16, 2);              //Initialize the display
  lcd.setBacklight(LED_OFF);
  lcd.cursor();
  pinMode(ledPin, OUTPUT);
  pinMode(speakerPin, OUTPUT);
  if (debug)
    Serial.println("\nSTART");
void loop ()
  if (true) {
    convert2Morse(Serial.readString());
  else if (false)
    lcd.print("no u.");
void convert2Morse(String message)
  for (int pos = 0; pos < message.length(); pos++)
    if (debug)
      Serial.print(message.charAt(pos));
      Serial.print("   ");
      lcd.print(message.charAt(pos));
      lcd.print(" ");
    if ((message.charAt(pos) >= 97) && (message.charAt(pos) <= 122))
      morseLED(morseATable[message.charAt(pos) - 97]);
    if ((message.charAt(pos) >= 48) && (message.charAt(pos) <= 57))
      morseLED(morseNTable[message[pos] - 48]);
    if (message.charAt(pos) == 32)
      morseLED("       ");
    if (debug)
    lcd.clear();
void morseLED(String sequence)
  for (int pos = 0; pos < sequence.length(); pos++)
    flashLED(sequence.charAt(pos));
  delay(2 * dot);
void flashLED(char dotOrDash)
  if (debug)
    Serial.print(dotOrDash);
  lcd.print(dotOrDash);
  if (dotOrDash == 46)
    digitalWrite(ledPin, HIGH);
    tone (speakerPin, pitch1);
    delay(dot);
    digitalWrite(ledPin, LOW);
    noTone(speakerPin);
    delay(dot);
  else if (dotOrDash == 45)
    tone (speakerPin, pitch2);
    delay(dash);
    noTone(speakerPin);
    delay(dot);
  else if (dotOrDash == 32)
    delay(dot);
I will try to learn the other stuffs in the code
  if (debug)
Printing of "START" will only occur when debug has been set to true, and there are other sections of code that will only be executed if debug is true
When the program is tested and working set debug to false for the final version of the program
