Can anyone explain how I got this to work??
#define Serial.printf(...) {if (doVerbose) { Serial.printf(VA_ARGS); } }
Got it to? Or get it to?
The macro takes an argument (or more than one). All arguments are passed to a real function that is defined as taking a variable number of arguments.
That macro cannot work, periods (.) are not allowed in identifiers. Create a method instead.
Danois90:
Oops! Better read up on macro syntax, functions that take a variable number of arguments, like printf. THOSE periods are absolutely allowed. They are an ellipsis, which is how you indicate a function takes a variable number of arguments.
Regards,
Ray L.
RayLivingston:
Regards,
Ray L.
No, you better read up on the term "identifier": #define identifier content, in the context of this thread "Serial.printf" is used as identifier and this is not allowed.
These macros all work.
... is allowed.
// Example of use:
// #define DEBUG // <---<<< this line must appear before the include line
// #include <DebugMacros.h>
//If you comment the line: #define DEBUG
//the Macro lines are defined as blank, thus would be ignored by the compiler
//#define DEBUG // if this line is NOT commented, these macros will be included in the sketch
//examples:
// This converts to >>>>-----------------------> This OR a Blank Line.
// DPRINTLN("Testing123"); Serial.println("Testing123");
// DPRINTLN(0xC0FFEEul,DEC); Serial.println(0xC0FFEEul,DEC);
// DPRINTLN(12648430ul,HEX); Serial.println(12648430ul,HEX);
// DPRINTLNF("This message came from your flash"); Serial.println(F("This message came from your flash"));
// DPRINT(myVariable); Serial.print(myVariable);
// DELAY(100); delay(100);
// PINMODE(9600); pinMode(9600);
// TOGGLEd13; PINB = 0x20; // D13 Toggle,for UNO ONLY
// Also, this works #define INFO(...) { Console->printf("INFO: "); Console->printf(__VA_ARGS__); } >>>---> where {} allows multiple lines of code.
// See: http://forum.arduino.cc/index.php?topic=511393.msg3485833#new
#ifdef DEBUG
//examples:
//#define DPRINT(args...) Serial.print(args) OR use the following syntax:
#define SERIALBEGIN(...) Serial.begin(__VA_ARGS__)
#define DPRINT(...) Serial.print(__VA_ARGS__)
#define DPRINTLN(...) Serial.println(__VA_ARGS__)
#define DRINTF(...) Serial.print(F(__VA_ARGS__))
#define DPRINTLNF(...) Serial.println(F(__VA_ARGS__)) //printing text using the F macro
#define DELAY(...) delay(__VA_ARGS__)
#define PINMODE(...) pinMode(__VA_ARGS__)
#define TOGGLEd13 PINB = 0x20 //UNO's pin D13
#define DEBUG_PRINT(...) Serial.print(F(#__VA_ARGS__" = ")); Serial.print(__VA_ARGS__); Serial.print(F(" "))
#define DEBUG_PRINTLN(...) DEBUG_PRINT(__VA_ARGS__); Serial.println()
#else
#define DPRINT(...)
#define DPRINTF(...)
#define DELAY(...)
#define TOGGLEd13
#endif
Yes, but this will not:
#define Serial.printf(...) {if (doVerbose) { Serial.printf(__VA_ARGS__); } }
"Serial.printf" is not a valid identifier because of the dot. Even if it was, the macro would recursively call itself causing an endless loop - or an error from the pre-processor.
Danois90:
Yes, but this will not:#define Serial.printf(...) {if (doVerbose) { Serial.printf(__VA_ARGS__); } }
If it were a valid identifier, the pre-processor wouldn't expand the macro recursively if it's part of its own definition.
